Navigating the Path of Life: One Question to Find the Way
  • Thread starter Remnant
  • Tags
    Life Path
In summary, when faced with two gnomes, one guarding the path to heaven and the other the path to hell, who may both be liars or truth-tellers, the best question to ask in order to determine which path is which is: "If I asked you if this is the road to hell, would you say yes?" This question takes advantage of the nature of liars and truth-tellers, making it possible to determine the correct path with only one question.
Remnant
Let us say, when a person dies. He comes to a path (purgitory) or so. He walks down this path and gets to a fork in the road like a "Y". One gnome guards each path, one gnome tells falsehoods, the other tells the truth. One of the paths leads to heaven and one of the paths leads to hell.
*You do not know which path is which, or which gnome is which*
&You only have 1 question to ask both gnomes, and if you ask one know a question, you have to ask the other gnome the exact same question- in turn that will use up your one question!
What is the answer(let us say there are no flaws).
a rivision of the above post..
*what would be one question you could ask, that would alow you to know what path leads to heaven and what path leads to hell?***
Answer 1:
While pointing to one of the paths, Ask one gnome "If I asked you if this is the road to hell, would you say yes?"
In this case, you don't need the second gnome. It's a double question and the liar must lie twice to answer it, and the two lies cancel each other out.
Answer 2:
Point back to the road from which you came and ask one of the gnomes "Is this the road to hell?". Then you will know if the gnome is a liar and so you will know if the other gnome is a liar. Then point to one of the paths and ask the other gnome the same question.
eom
sorry if i did not specify but you can only ask the gnomes one question and the question has to be asked to both of the gnomes.. so i have to discard your Answer 2, which was probably my fault from lack of explination. i came up with ask "what would the other gnome say is the path he guarding" and like your answer one. the gnomes would lie twice and that would cancel out. If one answered "hell" you would know the path he is on would be "heaven" vice-versa.
No, in your case there would be exactly one lie in the answer no matter which road and which gnome. That is why the road is to hell when the answer is heaven, and vice versa.
oh yeah your right.. i apologize.. yeah so the gnome would have to tell the truth about lying and the other would have to lie about telling the truth.. .therefore not llie twice.. but yeah.. but would my answer be valid? or just disreguarded.. when i was in high school.. we got half the school trying to figure that out.. it took me 2 days and my friend 3 days to figure it out.. i just want to verify if there are any other possible answers. which in your case yes, for your answer 1
How about...
If honest gnomes go to heaven and lying ones go to hell, which way do you deserve to go?
And you only need one gnome!
"Are you a liar?"
billiards said:
"Are you a liar?"
They would both answer no.
Proggle said:
How about...
They would both respond Heaven.
If you ask the lier what path the truthful one was on he'd say "hell" if he was in fact on the path to heaven or "heaven" if he was on the path to hell. Then when you asked the truthful one which path the lier is on he'd tell the truth and say either heaven or hell, depending on which ever was true, I don't see how this solves anything.
No, they would respond by saying which way they would go, not by where their destination was. I.e. each would say "I would go this way" and point to the road to heaven.
I'm pretty sure that if you go through the cases, you will find that Remnant's solution works as well. Because of the nature of the answerers, you can be sure that the answer will contain one lie and one truth. I.e. exactly one lie. Put another way, the Truther will truthfully report the liar's lie and the liar will lie about the truther's truth.
The question was "which way" not "to where", so either one of them would point towards the way to heaven.
This question is asking them to respond with an answer, not point in any direction.
I don't see anyone asking them to point.
The question is still asking them to identify the way, not the final destination.
It's irrelevant if the answer is "I would take the right way", or a pointing finger in that direction.
True, but irrelevant. They still have to answer the question that was asked, either by pointing or by some other means. Perhaps I should have said they would point out the road to heaven.
I like the logic of Proggle's solution, and after all, it is a logic puzzle. But it does have a minor flaw. The danger is that the answer will be "I deserve to take the road to heaven.". This would not be helpful. It is easily fixed though, the logic can be preserved with a question like:
If honest gnomes go to heaven and lying ones go to hell, do you deserve to go to the left or to the right?
-or-
You could point to one of the roads and ask:
If honest gnomes go to heaven and lying ones go to hell, do you deserve to go this way?
-or-
If honest gnomes go to heaven and lying ones go to hell, do you deserve to take the road that you guard?
eom
I would just say:
"If someone asked you whether your path leads to heaven, would you answer yes?"
And the answer would be true.
Since this is supposed to use logic, it would be illogical to assume that if you asked them a question that instead of answering they would merely point. If Spoc was here you would have gotten that Vulcan pinch thing he does. :devil:
Pointing works for me.
Rogerio said:
I would just say:
No, for example, if the lier is on the path to heaven, he would say no, so the truthful one would be on the path to hell and also say no. You've got 2 gnomes both saying no, so you have no idea which path they are on. Same if they were on opposite paths, they'd both say yes.
Good, because now that I think about it, I don't see that they would answer any other way. Human (and gnoman?) communication travels down many roads too. But for the gnome to describe which road in words and not gestures seems to me an unusual response. Indeed, he may not speak at all, but just point. The last time Spock pinched me that way it was because I was more logical than he, and he was jealous.
Think again:
"If someone asked you whether your path leads to heaven, would you answer yes?"If the lier was on the path to heaven, he would say "NO" to the person who asked the question.
So, he would say "YES" to me.
Forget the second gnome: ask once, and you will know the right path.
:smile:
This in answer to the question "What would the other gnome say is the path he guarding?"
Well this is convoluted isn't it. It's not a yes/no question. But let's edit the question to fit the discussion.
Would the other gnome say he is guarding the path to heaven?
Only one of the gnomes is a liar. If the liar was on the path to heaven, he would say no. But then the other gnome is not a liar so he faithfully reports the "no" of the lying gnome.
If on the other hand, the truther was on the path to heaven, he would say yes. But then the other gnome is a liar so he unfaithfully report "no". So no matter which gnome you ask, the one on the road to heaven will say no. And that's a good thing isn't it?
... So no matter which gnome you ask, the one on the road to heaven will say no.
Hi Jimmy,
Thats right, too!
If you use my question, the one on the road to heaven will say "yes".
:smile:
i say you just ask one of the grones which way was heaven. if he lied, run back and take the other path. easy. =)
Really easy...:-)
(but how do you know who is the lier?)
well, if you find yourself walking on fire then you know you are on the wrong path. but if you see angels, thank the grome!
Sorry Rogerio, I really messed things up. In my mind I was confusing your answer with Remnant's answer. Very embarrassing.
Your answer is good. But then you should have guessed that I would praise it as it matches my own answer in message #3 of this thread.
Rogerio said:
Think again:
:smile:
That doesn't make any sense.
WHAT?
OK...
Two gnomes
One is on the path to heaven, the other is on the path to hell.
You don't know which gnome is the liar
You don't know which path either gnome is on
So...
jimmy said:
Question - Would the other gnome say he is guarding the path to heaven?
False, he would say yes, because he's lying. Remember, you are asking the lier if the truther on the path to hell would say he is guarding the path to heaven. The truther would say no, so the lier says yes.
What? The truther, when asked if the other gnome would say he's guarding the path to heaven, would say no, because the lier is on the path to heaven, so the lier would say no.
So, you have one gnome saying no and one gnome saying yes, you don't know which is lying and you don't know which path they're on. At this point you know nothing.
This isn't hard to follow guys.
:cry:
I'm very sorry for you...
jimmysnyder said:
... it matches my own answer in message #3 of this thread.
I've just read it, and you are right, Jimmy : they are equivalents !
  • #31
There is one gnome standing in front of a door. The door leads to heaven or hell and the gnome always lies or always tells the truth. There is one question (and variations of it) that will determine all of the variables. (edit - not true. It only determines where the door leads. If the gnome is honest or a liar is undetermined, but irrelevent.)
So I ask him, "If I asked you where this door leads, would you tell me it leads to heaven?"
Ok, assume the door leads to heaven.
If someone asked the truthful gnome if the door went to heaven he would answer 'yes,' so his answer is 'yes.'
If someone asked the liar if his door leads to heaven he would answer 'no,' so his answer to me will be 'yes.'
In either case I can be sure that this is indeed the door to heaven. If I ask the same question and the answer is 'no' then I know the door leads to hell. The question isn't asking where the door leads. The question is asking what they would say if asked another question. In this logic argument two truthful statements combined is still a truthful statement, and two lies cancel each other out and become a truthful statement.
  • #32
there is a point there. so most likely, you will still go through thedoor right?:rolleyes:
  • #33
Rogerio said:
I would just say:
It is OK.
Wrong.
According to your example, if someone had asked the liar gnome, the gnome would have answered "no" . So, that gnome would say "yes" to Rogerio.
BTW, this is a classical puzzle (google: liar truth teller).
Jimmysnyder and Rogerio are absolutely right.
  • #34
Evo said:
...This isn't hard to follow guys.
I think so but... are you sure of that?
  • #35
I didn't complete the comparison because I thought it was obvious.
Ok, now assume the door leads to hell.
If someone asked the truthful gnome if the door went to heaven he would answer 'no,' so his answer is 'no.'
If someone asked the liar if his door leads to heaven he would answer 'yes,' so his answer to me will be 'no.'
The way the question is phrased it is irrelevant if the gnome is honest or if he is lying. Which door I would choose is also irrelevent, but at least I would be able to make an informed choice.
  • Quantum Interpretations and Foundations
  • Electrical Engineering
  • STEM Career Guidance
  • Quantum Physics
  • Quantum Physics
  • General Discussion
