| Thread Closed |
Origional Isomorphisms |
Share Thread | Thread Tools |
| Dec16-05, 10:36 AM | #1 |
If an group G is isomorphic to a group G(prime) then they are only equal or approximately equal. If this can continue on, i.e. G(prime) is isomorphic to a group W... then we are not sure if G is the origional group. Is it possible to find a group that is an origional isomorphism? Does this question even make sense to ask? thanks.
| Dec16-05, 10:48 AM | #2 |
Recognitions:
Equal and isomorphic are not the same, and origional isn't even a word.
In general it only makes sense to say two things in maths are equal if they are 'exactly the same thing', thus if we take the group of symmetries of the n-gon where n is even, eg the square or hexagon, then the stabilzer of one vertex equals the stabilizer of the opposite vertex (and is the reflection through those vertices plus the identity), whereas the stabilizers of two arbitrary vertices are merely isomorphic but not equal. |
| Dec16-05, 12:28 PM | #3 |
Isomorphism does not mean equal, but let's say you have an isomorphism between G and H, with the isomorphic function being f, which is known. My thoughts are that if you are working with a group, and just hate doing multiplication (or whatever the binary operation might be) in group G, but doing it in H isn't as bad. Wouldn't it just make sense to use f to map the necessary numbers to H, and then map them back to G with the solution? Just curious. |
| Dec16-05, 04:18 PM | #4 |
Origional Isomorphisms (IOW, it depends)
| Dec16-05, 05:30 PM | #5 |
Similarly, it makes no sense to talk about "a group that is an original isomorphism". A group is not an isomorphism- an isomorphism is a function between two groups. |
| Dec16-05, 06:00 PM | #6 |
| Dec16-05, 06:27 PM | #7 |
Recognitions:
[quoteto H, and then map them back to G with the solution? [/QUOTE] |
| Dec16-05, 09:23 PM | #8 |
| Dec17-05, 04:36 AM | #9 |
Recognitions:
And I am saying that finding an isomorphism between two groups is genuinely hard (in the computational sense as well).
| Dec17-05, 05:31 AM | #10 |
| Dec17-05, 05:43 AM | #11 |
Recognitions:
There are certainly some presentations of an abstract group that are easier to work with than others, if that's what you mean. Though I have no idea what 'hard composition' might mean, and unless you're going to tell me *how* you're going to give me two elements, and what kind of identification you want me to make from the answer to some preferred set of descriptions, then I can't offer any opinion. After all if you give me a and b the composition is ab. But perhaps you're asking me: given a and b and another element c is ab the same as c? As a simple case in S_3 the composition of (12) and (23) is (12)(23), it is also (123).
| Dec17-05, 12:20 PM | #12 |
Let's say you have a and b in group G, but for some reason it's pain in the *** to find ab. If there is an isomorphism f to H, where finding f(a)f(b), wouldn't it just be easier to map it to H, find f(ab) is much easier, then map it back to G. But like Hurkyl said, applying f or f^-1 will probably be just as bad or worse than just simply finding ab. |
| Dec17-05, 12:30 PM | #13 |
I didn't say "probably", I said "might".
Transforming a problem into a more efficient format is a common optimization theme. For example, when doing linear algebra on a computer, matrices are usually stored as a vector. (And for certain operations, are sometimes even converted into different things that can be manipulated more efficiently for that operation)
| Dec17-05, 12:49 PM | #14 |
Recognitions:
I know what you're saying and as far as i can tell it is full of mights, maybes, and perhapses. Try and find an example instead of speculating wildly. |
| Dec21-05, 10:42 AM | #15 |
Jason: Yes, the method you suggest can be employed for calculating integral transforms (convolving is harder than multiplying). f and f^-1 may be hard, but there are tables for them. Note that these contexts are not purely group-theoretic, but the idea is the same.
Matt grime: what's your deal? When some one asks a question, why do you speak of unrelated things? Someone says "I have two groups and an isomorphism", and respond with "isomorphisms are hard to find"? You claim that you knew what he was asking, so why did you change the subject? It seems like you're being deliberately obtuse. |
| Dec21-05, 11:11 AM | #16 |
Recognitions:
If some one asks about using isomorphisms to make things easier then surely it is reasonable to point out that finding an isomorphism is a (computationally) hard thing to do? Or perhaps I misread the first post of Jason's (which I believe I did). Very rarely do you have two groups and an explicit isomorphism in any practical situation. Since the question is about practical considerations surely that is a reasonable point to raise.
Certainly if you know a set of matrices of size 10^6 square is isomorphic to C_n as a group you ain't going to multiply together two large matrices, are you? So the answer is obviously, yes, isomorphisms can save you a lot of work. I can't believe this question even needs to be asked. However, determining the structure of even known abelian groups is hard (eg points on elliptic curves over finite fields). Since obtuse means blunt (or even insensitive) then it is probably exactly right to say I am being deliberately obtuse. You might also want to consider the fact that Jason raised a question unrelated to the original point of the thread if you're going to accuse people of bringing up unrelated things. |
| Dec21-05, 11:59 AM | #17 |
Just like matt grime said, the answer is obvious. I should have never of asked. I just wanted some certainty. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Origional Isomorphisms
| Can isomorophisms be really random? | Linear & Abstract Algebra | 2 | ||
| isomorphisms | Calculus & Beyond Homework | 1 | ||
| How do I find an isomorphism between Sn+m and Zn x Zm? | Linear & Abstract Algebra | 4 | ||
| isomorphisms | Linear & Abstract Algebra | 3 | ||
| What are Isomorphisms | Linear & Abstract Algebra | 10 | ||
