Momentum of a photon and Einstein
The discussion revolves around the concept of photon momentum as proposed by Einstein and its relation to classical definitions of momentum. Participants explore the transition from Newtonian momentum (mass times velocity) to the expression for photon momentum (p = h/w), questioning the implications of massless particles in this context. The scope includes theoretical aspects of quantum mechanics and historical development of these ideas.
  • Historical
  • One participant notes Einstein's definition of photon energy (E = hf) and momentum (p = h/w) and questions how this relates to classical momentum.
  • Another participant suggests that "momentum" in the relativistic sense may differ from the Newtonian definition, proposing that there could be a more general equation for momentum that applies to massless particles.
  • One participant presents a derivation of photon momentum, equating it to p = hf/c, leading to p = h/w, referencing a textbook for support.
  • Another participant expresses confusion about how a massless particle like a photon can possess momentum, indicating a potential divergence from classical definitions.
  • A participant asserts that the Newtonian formula for momentum is inadequate for relativistic cases, explaining that Einstein's framework provides a different understanding of momentum for massless particles.
  • Historical context is provided by a participant outlining the contributions of Planck, Einstein, and deBroglie in connecting energy, momentum, and the wave-particle duality of light.
  • One participant summarizes the relationship between energy and momentum for photons, reiterating the equation p = h/λ.
Participants express various viewpoints on the relationship between classical and relativistic momentum, with no consensus reached on the implications of photon momentum or the adequacy of classical definitions. The discussion remains unresolved regarding the interpretation of momentum for massless particles.
Some participants rely on classical definitions of momentum, which may not fully apply in relativistic contexts. The discussion also touches on historical developments that are not universally agreed upon, indicating potential gaps in understanding among participants.
Moneer81
Hello,
I am trying to teach myself quantum mechanics so take it easy on me.
In 1905, Einstein proposed that light is made of photons and that each photon carries energy E = hf (f is frequency) and momentum p = h/w (where w is wavelength)
My question is how did he go from the definition of momentum which is mass times velocity to the aforementioned p = h/w. Is there an easy straightforward answer to this or is it something derived from classical thermodynamics?
thanks
I don't know the answer, but...
I don't think the word "momentum" refers to precisely the same thing in the relativistic sense Einstein was using it, as it does in Newtonian mass*velocity.
Or perhaps the Newtonian equation is just a simplified "good enough" version of what's really going on, and is not the true equation? Like, maybe there's an equation of momentum that doesn't refer to mass, so that the momentum of massless particles with energy can be calculated as well as the momentum of massive particles.
Interested to see what the answer is, myself.
I understand it goes like this:
p = mv = mc = mcc/c = E/c = hf/c = hc/cw = h/w.
I think this is what my textbook "Quantum Mechanics" by Bransden & Joachain page 39 is saying.
yeah I'll be interested to figure this out a little better too.
You also raised an interesting question, if the photon is a massless particle that what does it mean for it to have momentum?
For me momentum is a property of mass but I guess you might be right, the momentum Einstein was talking about might be something different that the classical momentum that we are familiar with.
ok well that makes mathematical sense to me
The Newtonian formula for momentum is incorrect, it is accurate for non-relativistic motion (velocity much less than that of light) but for relativistic cases (velocity comparable to that of light) it is inadaquate. A photon is an example of relativistic speeds and thus Newtonian mechanics fails, as Einstein showed.
The correct equation for the energy of a body of rest mass m in the relativistic case is
E²=(mc²)²+(pc)²
Where p is the momentum of the body, which is not mv. For a photon m=0, so we get E=pc. According to Planck, the energy E of a photon is hf, so hf=pc. Rearranging we get p=h/wavelength. Notice also that when p=0 (i.e. in the rest frame) we obtain E=mc².
The derivation given by someone else in here doesn't work as it relies on the classical definition of momentum.
I just want to clarify the history.
1. Planck suggested E=h\nu to understand the high frequency spectrum of black body radiation.
2. Einstein used Planck's suggestion to understand the photo effect.
3. The connection with momentum was first made by deBroglie to give a wave understanding of the Bohr hypothesis, leading to QM.
4. It had been known since Maxwell that light had both energy and momentum densities, connected by E=pc.
To put things together:
[tex]p = \frac {E}{c} = \frac {h \nu}{\lambda \nu} = \frac {h}{\lambda}[/tex]
  • · Replies 38 ·
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 58 ·
  • · Replies 81 ·
