How Do Electric Fields Influence Electron Movement and Force Calculations?
  • Thread starter Thread starter mustang
    Field
The discussion revolves around the influence of electric fields on electron movement and the calculations of forces in various scenarios. Participants are exploring problems related to electric forces, electric fields, and their interactions with charged particles, specifically electrons.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss using Coulomb's law and the relationship between electric field and force. Questions arise about finding the electric field strength at the surface of a dome and the implications of Gauss's law. There are inquiries about the initial steps needed to solve the problems presented.
The discussion is ongoing, with participants seeking clarification on concepts and approaches. Some guidance has been offered regarding the use of Coulomb's law, while others are questioning the application of Gauss's law and the conditions within the dome.
One participant notes that they have not learned Gauss's law, which may limit their ability to engage with certain aspects of the problems. There is also mention of the electric field strength being zero inside the dome, which is under discussion.
mustang
Problem 3.
Given: k_e=8.98755*10^9 Nm^2/C^2 and g=9.81m/s^2.
An electron is released above the Earth's surface. A second electron directly below it exerts just enough of an electric force on the first electron to cancel the gravitational force on it.
Find the distance between the two electrons?
Note: What formula would you use?
Problem 18.
Given: k_e=8.98755*10^9Nm^2/C^2.
The dome of a van de Graaff generator receives a charge of .6*10^-4 C. The radius of the dome is 5.7m.
Find the magnitude of the electric field strength inside the dome. In units of N/C.
Note: What formula would you use and what to do first?
Problem 21.
Thunderstorms can have an electric field of up to 3.37*10^5 N/C.
What is the magnitude of the electric force on an electron in such a field?
Note: What would I do first?
Use Coulombs law , use the relation between Electric field and Force
For problem 18
For problem 18 then of having to find magnitude of the electric field strength inside the dome how would I find the magnitude of the electric field strength at the surface of the dome and the magitude of the electric field strength at the surface of the dome?
Have you learned Gauss's law?
Is there any charge inside the dome?
No I haven't learned Gauss' law.
There is 0 electric field strength inside the dome,
  • · Replies 16 ·
