Why Is Flatband Voltage of a MOS Capacitor Linked to Work Function Differences?
  • Thread starter Thread starter antonantal
    Capacitor Voltage
The discussion centers on the relationship between the flatband voltage of a MOS capacitor and the work function differences between the semiconductor and the gate metal. Participants explore the implications of energy band bending when the gate-source voltage is zero, delving into the definitions and physical principles involved.
  • One participant questions why the flatband voltage corresponds to the energy difference between the work functions of the semiconductor and the gate metal, seeking clarification on energy band bending.
  • Another participant introduces the concept of different types of MOSFETs, suggesting a need for further study before providing a detailed explanation.
  • A participant asserts that the definition of flatband voltage is a choice made by physicists, implying that it is based on selected reference points for potential difference.
  • One contribution discusses the band bending in the semiconductor region and its dependence on the work function difference, indicating that a specific voltage is required to achieve flatband conditions.
  • A later reply emphasizes the mismatch in band structures between the metal gate and bulk silicon, suggesting that the flatband voltage serves to align these structures and maintain a flat potential distribution.
  • Another participant notes that the flatband voltage can be influenced by additional device parameters, such as oxide charge, beyond just the work function difference.
Participants express differing views on the specifics of how flatband voltage is defined and its implications, indicating that multiple competing perspectives remain without a consensus on the topic.
Some participants express uncertainty regarding the definitions and implications of terms used, and there are references to external resources for further clarification, suggesting that the discussion may rely on varying interpretations of the concepts involved.
antonantal
Why is the flatband voltage of a MOS capacitor equal to the voltage corresponding to the energy difference between the work functions of the semiconductor and the metal of the gate? In other words, why and how are the energy bands bent when the gate-source voltage is zero?
Hello,
i don't know if I've understood you right, because my english is not as good as it should be :biggrin:
So, i try to explain like I've understood you.
Well, there are two kinds of MOSFET
First the enhancement transistor and then the depletion transistor.
The second one transistor will conduct if U_GS is either positiv or negativ << and not zero >>!
But at this point I'm not sure, so i'll repost when I've read my study documents at home and you still need it.
I'll explain the functionality of a MOSFET to you later, because i don't know if this is the answer that you need and this theme is too big and complicated for answering for nothing.
So, when this is what you are searching for, post again.
regards URI
______________________________
hope my english is not too bad.
My knowledge of electricity is not as bad, but my english :rolleyes: !
So if you notice gramatical mistakes please improve me.
Thanks, but my question is not "how does a MOSFET work?". It is much more specific.
I am not exactly sure what you are asking but I think the answer is, because that's how the physicists chose to define flatband voltage. I mean, a voltage is the potential difference between two points, so those are the points they picked.
For why bands bend see section 2.3.5 of
http://ece-www.colorado.edu/~bart/book/book/chapter2/ch2_3.htm
Is gate and source, the anode and cathode of the MOS cap? Is so then,
for how see Figure 3.2.3 or Figure 3.2.4 with Va=0.
http://ece-www.colorado.edu/~bart/book/book/chapter3/ch3_2.htm#3_2_4
Hope that helps...
Thanks es. That answered my question.
Hope that helps...
If you draw the band diagram of MOS structure you can see a band bending of semiconductor region. The bending of bond depends on the work function difference of metal and semiconductor to make flat of the bend bond there is a requirement of voltage which makes generation of charge which makes a bend of energy level in opposite direction that makes a flat band.
I realize this is an old thread, but I came across it when I was looking on Google, so thought I would add a bit incase it helps any students etc. looking here for an answer.
The band structures in the different materials are different, which I guess is obvious. But in semiconductors it is a very close match across the various interfaces. A simplistic way to think about this is to imagine the mismatch in the band structure between the metal gate and the bulk silicon. the flatband voltage is the voltage applied to the gate electrode in an effort to try and line up the band structure across the different materials, so that the potential distribution going from the metal, to the oxide, to the bulk does not change, it is flat (hence flatband voltage)
Flat band voltage is effected by a few perameters in the device, but generally it is the difference in work functions between the metal and the bulk silicon. As the work function is related to energies in the band structures they can be described in terms of potential and so result in an offset voltage to compensate, i.e. so the zero (or low voltage condition) is actually a few tenths of a volt bigger than or less than 0V. Please note: other device perameters can effect the flatband voltage such as oxide charge.
