Electron hole theory in Semiconductors
In summary, the electron hole theory is a way to describe the behavior of electrons inside semiconductors. This theory uses the concept of an electron hole, which is just the absence of a electron in a energy band. The holes move around in and out of a potential difference, just like a positivly charged electron.
slaw
Hi guys. Could someone please explain to me this electron hole theory that people use to describe the behavior of electrons inside semiconductors? How do these holes move, in and out of a potential difference?
Thanks guys.
The holes are just the abscence of a electron in a energy band. But its easier to describe the abscence of a electron as a single moving positive charge than it is to describe the motion of all the other electrons in the band.
Think of it like this. In a band you have N electrons. Remove one of those electrons(by for instance p-doping) and you have N-1 electrons left. Now you can either choose to describe this with the behavior of those N-1 electrons. Or you can choose to describe it as if there is one single hole moving around in the band.
So mathematicly the holes behave just like a positivly charged electron.
But the holes themself never move in or out of potential differences because the holes are just a mathematical trick. What moves in and out of those potential differences are the N-1 electrons.
I hope this explanation makes sense and answered your question :)
Stricly speaking, you can treat this as a band with one single hole and N electrons. But since a filled band (with N electrons) can not produce currents, the electrons can be ignored (to a very good approximation), and the band treated as though it had just the one hole.
Hm...I sort of understand the whole idea of the electron leaving to the conductor band leaving behind a hole which can act as a positive charge electron. But I don't understand how the electrons and hole will move when that piece of semiconducting material is used in a circuit. (Its really annoying how I keep spelling hole as whole...)
In an intrinsic semiconductor, a few electrons get thermally excited and break from their valence bond to become a free electron. This leaves behind a vacancy in its place called 'hole'.
In a P-type semiconductor, B with 3 electrons replaces a Si atom with 4 electrons in the lattice. 3 covalent bonds are formed by B with 3 neighbouring Si. But there is a deficiency of one electron in B for bonding with the 4th Si. This deficiency/vacancy is called a hole.
When an electric potential difference is present, the electrons from adjacent valence bond moves into the vacancy near it while moving along the potential.
The following represents the movement of valence electron.
Terminology:
* represents valence electron
_ represents hole
A is -ve and B is +ve.
..I A * * * _ * * * B
.II A * * _ * * * * B
III A * _ * * * * * B
IV A _ * * * * * * B
I- Hole is at the 4th position.
II- At first, the 3rd electron from left shifts right to fill the vacancy and leaves behind a vacancy in its place. The vacancy is at the 3rd position.
III- Next, the 2nd electron from left has shifted to the 3rd place and filled up that vacancy but leaves a vacancy at its place. The vacancy is at 2nd position.
IV- Now, the 1st electron from left moves to occupy the vacancy at the 2nd position creating another vacancy in its own place. The vacancy is at 1st position.
As the electrons moved right, the vacancy moved left. The vacancy is called a hole (just a shorter name for convenience). The movement of holes is really the movement of electron in the valence band. Therefore, the mobility of a hole is indirectly the mobility of valence electrons.
Mobility is the velocity acquired per unit electric field.
In the intrinsic and N type semiconductors, many free electrons are present i.e. electrons in conduction band which are free to move in the crystal as against valence electrons which can only move in the lattice points.
The right end of the material is applied a positive potential which attracts electrons. The electron which is at position 3 moves into the adjacent atomic vacancy at 4 due to the attraction and availability of free space to do so, otherwise it would have remained in its place. It created a vacancy in its previous atom which is used by the valence electron from 6. The electrons move from 3 to 4, 2 to 3, 1 to 2 and so on. This pushed back the vacancy step by step and it now stands at 1. Call it the hole and you may say tht "hole moved from right to left" while the "bonded electron moved from left to right". Hole is just a shorter name used for convenience.
Notice that the bonded electron and free electron move towards positive potential alike, because they are both electrons.
Hole movement is opposite to that of bonded electron(as can be understood from the illustration). So it is also opposite to free electron movement, infact, opposite to any electron movement! Also note that the velocity with which the bonded electron moves can be associated with the hole too since hole is simply a physical complement of the bonded electron. This means that their physical parameter like rate of change holds the same value for them both.
It's like those sliding puzzles where you slide tiles to try to make the picture. You actually slide the tiles but in effect, it's as if it was the missing tile that was tracing a trajectory.
http://en.wikipedia.org/wiki/File:15-puzzle.svg
Related to Electron hole theory in Semiconductors
1. What is electron hole theory in semiconductors?
Electron hole theory is a concept in solid state physics that explains the behavior of electrons and holes in semiconductors. In this theory, electrons are considered to be negatively charged particles, while holes are considered to be positively charged "absence" of an electron in the valence band.
2. How does the concept of electron hole theory explain conductivity in semiconductors?
According to electron hole theory, when an electron moves from the valence band to the conduction band, it leaves behind a hole in the valence band. This hole can then be filled by another electron, resulting in the movement of electron-hole pairs. This movement of charge carriers is what leads to conductivity in semiconductors.
3. What is the relationship between electron hole theory and band structure in semiconductors?
The band structure of a semiconductor refers to the energy levels of electrons in the material. In electron hole theory, the movement of electrons between these energy levels is explained by the concept of holes. As electrons move from the valence band to the conduction band, they leave behind holes in the valence band. This movement of electrons and holes is what determines the band structure of a semiconductor.
4. How does doping affect electron hole theory in semiconductors?
Doping is the process of intentionally adding impurities to a semiconductor in order to alter its electrical properties. In electron hole theory, doping can either increase or decrease the number of electrons or holes in a material, thereby affecting its conductivity. This is because the number of charge carriers in a material determines its electrical conductivity.
5. What are some practical applications of electron hole theory in semiconductors?
Electron hole theory is the fundamental concept behind many modern electronic devices, such as diodes, transistors, and solar cells. It is also used in the development of semiconductor materials for various applications, such as in computer chips and electronic sensors. Additionally, understanding electron hole theory is crucial for the advancement of technologies like quantum computing and nanotechnology.
  • Atomic and Condensed Matter
