What Is Particle Spin in Physics?
  • Context: High School
  • Thread starter Thread starter EIRE2003
    Spin
Particle spin is a fundamental property of particles in quantum mechanics, indicating how they behave under rotation. For instance, particles with spin 1, like gluons, require a full 360-degree rotation to appear the same, while spin 2 particles exhibit higher symmetry and only need a 180-degree rotation. Particles with spin 1/2, such as electrons, only return to their original state after a 720-degree rotation. Understanding these distinctions is crucial for grasping the behavior of particles in quantum physics.
  • Basic understanding of quantum mechanics
  • Familiarity with particle physics terminology
  • Knowledge of rotational symmetry concepts
  • Understanding of angular momentum in physics
  • Research the implications of spin statistics in quantum field theory
  • Explore the role of spin in the Standard Model of particle physics
  • Learn about the measurement of spin using Stern-Gerlach experiments
  • Investigate the relationship between spin and quantum entanglement
Students of physics, researchers in quantum mechanics, and anyone interested in the fundamental properties of particles and their behaviors in the quantum realm.
EIRE2003
Hey I am new to this and I am studing physics on my own and I am just wondering wat Spin actually is? is it when a particle such as a gluon is in a spin, in motion wit atomic geometry?
One way to think about spin is the following: when a particle has spin [itex]s[/itex], that means that when you rotate the particle over [itex]360/s[/itex] degrees the particle will look the same. So, spin 1 particles have to be rotated 360 degrees, but spin 2 particles have a higher symmetry and need only to be rotated over 180 degrees. Interestingly, there are also particles with spin 1/2 (such as the electron). That means that they do not look the same when you rotate them over 360 degrees! Only when rotated over twice 360 degrees will such a particle look the same. Quantum-fun...
Which direction will the spin be in space where there is no direction.
how will you measure an angle there?
-benzun
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 20 ·
