Thread Closed
Coating Al and Cu simultaneously
Share Thread Thread Tools
Sep6-06, 07:04 AM   #18
This is another zalman cooler:
http://www.zalman.co.kr/eng/product/...x=174&code=009
How is this thing coated? It's all copper.
Sep6-06, 08:50 AM   #19
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
It's a sandwich of 70 copper sheets, rather than a 24 sheet Cu sandwich between two 23 sheet Al sandwiches --- what coating? You want to plate it? Same problem as the Al-Cu-Al --- wicking of plating solutions between the sheets. Less bimetal problem, if there was one (doubt it), and no Al doing what Al does when in contact with salt air (corrode).
Sep6-06, 01:37 PM   #20
It's been coated with something to make it red. Most reviews that comment on the colour say it's been anodized, but copper can't be anodized, so what is it?
Sep6-06, 02:01 PM   #21
Recognitions:
Cu is a "red" metal. Cu can be anodized --- it isn't a tightly bound film as on Al, and isn't all that useful a process for anything. It's conceivable that you're looking at OFHC Cu --- "oxygen free, high conductivity" copper --- again, a "gilding of the lily" for heat sinks. Grab yourself a piece of heavy gauge copper wire, or scrap copper tube and play around a bit with a Bernzomatic, or whatever you can lay hands on for propane or butane torches --- oxidizing and reducing zones of the flame --- and with water and oil quenches of a piece heated to "red heat" at one end (use pliers --- it is a good heat conductor) --- you'll notice a gradation of color on the surface, red (black body emission red) through gray, black occasionally, and some almost bright reds (not red heat) as various oxides form, and decompose --- you'll see the color zones move as the temperature gradient develops toward steady state.
Sep7-06, 03:43 PM   #22
mmm....definately coated with something looking at these pictures...
You can see the base is the usual copper colour, but the fins are deep red.
Sep7-06, 05:32 PM   #23
Recognitions:
Retired Staff Staff Emeritus
I've seen a similar, reddish coating on magnet wire. I think the wire (Belden magnet wire) we have in the lab has a polyurethane + nylon doublecoat.
More here: http://www.mwswire.com/inschar.htm
Thread Closed
Thread Tools
Similar Threads for: Coating Al and Cu simultaneously
Thread Forum Replies
What kind of coating has the Ni, P and Fe? Materials & Chemical Engineering 2
Masters and Bachelors Simultaneously Academic Guidance 10
Particle seen in two different places simultaneously Quantum Physics 13
Aluminium Coating Materials & Chemical Engineering 2
Gold coating Classical Physics 1
