Impact Speed (?)
by Kalie
Tags: impact, speed
Kalie
Kalie is offline
#1
Aug30-06, 08:22 PM
P: 46
Ball bearings are made by letting spherical drops of molten metal fall inside a tall tower called a shot tower and solidify as they fall.
If a bearing needs 4.50 to solidify enough for impact, how high must the tower be?
What is the bearing's impact speed?
I got the answer for the first part correct it was 99.2
d=.5*9.8*4.5^2=99.2
but I am not sure how to approach the second part.....
I search all over but couldn't find an equation could someone help me with that.
All I need is the equation.....thank you
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
mezarashi
mezarashi is offline
#2
Aug30-06, 08:28 PM
HW Helper
P: 661
Look for the kinematics equations. Given all the information you have, you actually have a choice on the equation you want to use.
How about the intuitive: final velocity = initial velocity + (acceleration x time)
HallsofIvy
HallsofIvy is offline
#3
Aug31-06, 02:56 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
Quote Quote by Kalie
d=.5*9.8*4.5^2=99.2
You know that v= -9.8 t m/s2 and t= 4.5 s!
Register to reply
Related Discussions
gravity speed and force of impact General Physics 2
Relative Impact Speed Introductory Physics Homework 0
Water and High-Speed Impact Classical Physics 7
angular speed around a bar/clay system's center of mass after impact Introductory Physics Homework 1
