Motion of charged particle in a magnetic field
The discussion focuses on the motion of a positive point charge \( q \) with mass \( m \) injected into a uniform magnetic field \( B = B_0 i \) with an initial velocity \( u_0 = \mu_0 j \). The charge experiences a magnetic force \( F_m = q(u_0 \times B) = q \mu_0 B_0 k \), resulting in a semicircular trajectory in the \( yz \)-plane. The velocity remains constant while the direction changes due to the magnetic force, leading to a circular motion until the particle exits the magnetic field, at which point it continues in a straight line in the direction of its last velocity vector.
  • Understanding of Lorentz force and its application in charged particle motion.
  • Familiarity with vector cross products in physics.
  • Knowledge of circular motion and centripetal force concepts.
  • Basic principles of magnetic fields and their effects on charged particles.
  • Study the derivation of the Lorentz force equation in electromagnetic theory.
  • Learn about the principles of circular motion and centripetal acceleration in physics.
  • Explore the concept of magnetic field lines and their interaction with moving charges.
  • Investigate the effects of electric fields on charged particles in motion.
Students and professionals in physics, particularly those studying electromagnetism, as well as engineers working with charged particle dynamics in magnetic fields.
big man
OK first off here is the problem.
problem: A positive point charge q of mass m is injected with a velocity [tex]u_0 = \mu_0 j[/tex] into the y > 0 region where a uniform magnetic field [tex]B = B_0 i[/tex] exists. Obtain the equation of motion of the charge, and describe the path that the charge follows.
i, j and k represent unit vectors in the direction of the x, y and z axes.
Now I understand that the path will be a semicircle from the theory of the motion of a charged particle in a uniform magnetic field and since y > 0 and I know that the force experienced by the particle will be in the z direction.
[tex]F_m = q(u_0 X B) = q \mu_0 B_0 k[/tex]
The velocity is going to be constant, but the motion will vary with time in the z direction I think? Obviously my problem is that I'm not too sure of how to solve for the equation of motion in this problem. I guess one of the reasons why I'm finding this so difficult is I can't even visualise it properly.
Any help to put me on the right track would be great.
Thanks
EDIT: I can get the answer by simply equating the centripetal and magnetic forces and then substituting [tex]R= \frac {m \mu_0} {q B_0}[/tex] into the general equation of a semicircle, but I don't think this is how they want you to do it.
[tex]u_0 = \mu_0 j[/tex] That's the initial velocity when it enters the magnetic field.
The velocity does not remain in the j-direction though. The particle accelerates, i.e. changes direction.
If the 'speed' is constant, what can one say about the trajectory?
If it leaves the magnetic field, it will travel in a straight line in the direction of the velocity vector where it leaves the M field, unless subject some other E or M field, not parallel with the velocity.
