Thread Closed
perfectly elastic collision
Share Thread
Oct9-06, 09:08 AM   #1
2 blocks are free to slide along the frictionless wooden track. The block of mass m1=5.00 kg is released from A, while the block of mass m2= 10.0 kg initially sits @bottom of ramp. The blocks collide @ position Bin a perfectly elastic collision. To what height does m1 rise after collision?
Originally I thought of using Ki + Ui = Kf + Uf where U=mgh
so 1/2m1vi^2 1/2m2vi^2 + (mgh)i = 1/2m1vf^2 1/2m2vf^2+ (mgh)f
However I'm having a hard time figuring this out because I don't know what the velocities of either block is after collision. I do know that the initial of block 2 is 0 m/s. Can someone help me set this problem up? Any help is appreciated.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct9-06, 09:12 AM   #2
Mentor
What else is conserved in every collision?
Oct9-06, 11:52 AM   #3
In every collision... momentum
Oct9-06, 11:54 AM   #4
In elastic collisios kinetic energy
Oct9-06, 11:58 AM   #5
Mentor
Quote by bearhug
Right. You have to use that fact to solve this problem. (You just used conservation of energy--but that's not enough.)
Oct9-06, 03:38 PM   #6
Does gravitational potential energy have anything to do with this problem?
Oct9-06, 05:53 PM   #7
OK so I set up the problem beginning with (m1v1 + m2v2)i = (m1v1 + m2v2)f . Should I start this problem with block 1 m=5.0 kg w/ initial velocity after collision or before. If it's before than initial would be 0 but other wise it wouldn't. Since the question asks for the height after collision I was wondering if this needs to be considered in terms of what's initial and what's final. Any feedback please.
Oct10-06, 11:48 AM   #8
Mentor
Assuming I understand the problem correctly, here's how to approach it. First figure out the speed of block 1 just before it collides with block 2. Then analyze the collision to determine the speed of block 1 just after the collision. (That involves conservation of momentum and energy.) Once you know the speed of block 1 after the collision, figure out how high it goes.
Thread Closed
Similar discussions for: perfectly elastic collision
Thread Forum Replies
Perfectly Elastic Collision Problem Introductory Physics Homework 15
[SOLVED] Perfectly Elastic Collision Introductory Physics Homework 5
Mastering Physics: Collision on an incline plane and perfectly inelastic collision Introductory Physics Homework 2
perfectly elastic collisions Introductory Physics Homework 10
Perfectly elastic collisions (proof) Classical Physics 1
