Thread Closed
stress-energy tensor in curved spacetime
Share Thread Thread Tools
Oct20-06, 05:48 AM   #1
In any textbook on relativity, one finds the classical expression for the stress-energy tensor of a perfect fluid. In generalizing this tensor to curved spacetime, one just replaced the flat-spacetime metric tensor by the metric tensor of curved spacetime. It seems logical to do so, but in my view there is no certainty that this is indeed the correct generalisation. Maybe the generalisation could be defined differently. So, how can we know for sure that we use the correct form of the stress-energy tensor in Einsteins Field equations ? Does there exist experimental evidence that we have indeed the correct tensor ? Also for the stress-energy tensor of the electromagnetic field, one could pose the same questions.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct20-06, 07:41 AM   #2
Quote by notknowing
Why would you need to 'generalize' it? A tensor is a geometrical object which exists independantly of the presence of spacetime curvature. The definition of the tensor doesn't change when going from flat spacetime to curved spacetime. Can you please clarify this "generalizing" that you're refering to? Thanks.
Pete
Oct20-06, 10:41 AM   #3
Quote by pmb_phy
Pete
I'm afraid it is not so simple as you indicated.
In the book Gravity by J. Hartle, one can read on page 480 : "There is some ambiguity but little difficulty in generalizing stress-energy tensors to curved spacetime". The way to generalize seems to be described by "the principal of minimal coupling" which is briefly described in wikipedia : "Also, under the principle of minimal coupling, the physical equations of special relativity can be turned into their general relativity counterparts by replacing the Minkowski metric (ηab) with the relevant metric of spacetime (gab) and by replacing any partial derivatives with covariant derivatives. "
Now, I'm not sure whether this "principal of minimal coupling" is to be understood as a recepy (which works most of the time), or as a strict mathematical principle. I found some other internet references where one mentions that there exist other approaches too, such as "conformal coupling", though I must admit that I don't understand this. In any case, there seems to be an ambiguity in the exact form of a stress-energy tensor in GR. If this is the case, why are certain stress-energy tensors (like the one of a perfect fluid) given as facts in most textbooks ? Could it just be wrong ?
Oct20-06, 01:42 PM   #4
Recognitions:
Retired Staff Staff Emeritus
I'm not sure what Hartle is getting at either.
I've seen the "minimal substitution rule" described as follows (Wald:70)
[tex]\eta_{ab} \rightarrow g_{ab} \hspace{.5 in} \partial_a \rightarrow \nabla_a [/tex]
I.e. one replaces the Minkowski metric with the space-time metric, and ordinary partial derivatives with the covariant derviatve.
This process usually works, but not always, because covariant derivatives don't in general commute. The above process doesn't guarantee the correct ordering. I could dig up an example of where it fails if there is further interest, but I'm not sure I want to go that deep yet.
Unfortunately, if covariant differentiation has anything to do with the stress-energy tensor, I'm not aware of the connection.
It would be worthwhile looking at Hartle to see if his notion of "minimal substitution" is the same as Wald's and to see what he has to say about it to gain some illumination on what he's trying to say.
Onto the stress-energy tensor. I don't know what Hartle has in mind, but I'll talk about some generalities anyway, in the next post.
Oct20-06, 02:12 PM   #5
Recognitions:
The stress-energy tensor
Any curved manifold can be seen as "locally flat". In GR, in a local region, we can always replace the metric gab with a Minkowskian metric [tex]\eta_{ab}[/tex]. This ties in with the principle of "minimal substitution" as mentioned earlier, so hopefully it's the sense that Hartle hand in mind.
We can use the local Minkowskian metric to define the amount of energy and momentum (the energy-momentum 4-vector) contained in a small volume element at any given time by the rules of special relativity in this locally flat section of the manifold.
I'm not aware of any ambiguities here. The volume elements will be very small, so little "gotchas" regarding the relativity of simultaneity in a volume element shouldn't be an issue. The metric will naturally define a local coordinate system which can be used to give the specific components of the energy and momentum. This will in general not be an orthonormal coordinate system of course.
The remaining issues boil down to - "how do we naturally specify a volume element on a 4-d manifold"?
The standard way of doing this is to represent a volume in a 4-d manifold as a vector - a vector orthogonal to the volume element. Perhaps this is ambiguous, but I'm not aware of how. It can be justified a bit more formally in terms of geometric algebra.
Note: the following is optional and a bit advanaced, but I think it's interesting. If you are already familiar with vectors and their duals, one-forms, it can be quite illuminating. But the whole purpose of this section of the post is only to discuss in more detail how we can represent a volume element by the vector orthogonal to it.
In geometric algebra, one can represent a volume element as the interior region of a parallelpiped formed by three vectors. One can also think of it as the interior region of three one-forms. If you have MTW, you should have run across the visual image of one-forms as "stacks of plates'.
The idea of a volume element can be expressed as the geometric product, also known as the wedge product
http://www.mrao.cam.ac.uk/~clifford/...tro/intro.html
of three one-forms. It's actually an oriented volume. This means that volumes can be represented as three-forms, because the wedge product of three one-forms is a three-form.
Rather than work with the three-forms, we work with their duals (this is the Hodges dual). There is a long complicated discussion in MTW that's not very intuitive, the geometric picture of a dual as described in
http://www.mrao.cam.ac.uk/~clifford/...00000000000000
is a lot easier. Every three-form has a unique "hodges dual', which is an ordinary one form. Thus the "natural" way to represent volumes is with a one form (or equivalently, a vector). This is the Hodges dual of the three form.
Note that there are two types of duality here - there is a duality between one forms and vectors, this is a different sort of duality than the Hodges duality, which is the duality between one-forms and three-forms.
So, in conclusion - the stress-energy tensor simply takes a vector-valued volume element and converets it into the local energy-momentum 4-vector. It can therefore be regarded as the "density" of energy and momentum.
Oct20-06, 02:58 PM   #6
Quote by notknowing
Do you have a scanner? If so then please scan in that page and any other page which requires to be included for context. I find it hard to believe that Hartle is saying what you think he is. Thanks. You can either post the pages here or e-mail them to me.
That applies to tensor equations, not to the tensors themselves.
No ambiguity exists. A tensor can be defined as a multi-linear function of vectors and 1-forms to real numbers. This function does not depend on the components of the vectors/1-forms nor does it depend on the components of the tensor itself. You can evaluate the tensor in any system of coordinates to your liking. The locally Minkowski coordinates are usually the easiest since it has the same form as in flat time in globally Minkowski coordinates. As such the components of the tensor are well-defined making the tensor well-defined.
Best wishes
Pete
ps - I just e-mailed the author for clarification. Most authors are often willing to respond and clarify. Is this a text which is in depth (i.e. tensors, differential geometry, etc.)? I think I may pick up a copy.
Oct20-06, 05:15 PM   #7
This is the response I got from the author
Dear Pete: This is an oblique reference to the following issue:
Stress-energy tensors in curved spacetime can have terms in them
proportional to the spacetime curvature (the Einstein tensor for
instance). The spacetime curvature vanishes in flat spacetime. Thus
knowing the SE tensor in flat spacetime doesn't determine how much of
such curvature terms appear in generalizing to curved spacetime (the
ambiguity). On the other hand there is always the straightforward
generalization leaving out such terms (the little difficulty). I
agree it could have been said better.
Jim Hartle
Now if someone can explain to me what he means when he said that ....
Do you like this text? I'm thinking about picking up a new text on GR.
Best wishes
Pete
Oct20-06, 11:03 PM   #8
Recognitions:
It is useful to think of the decomposition of a stress-energy tensor into density and pressure terms as an eigenvalue problem. In particular, look at the solutions of
[tex]
T^{a}{}_{b} v^{b} = \lambda_{v} v^{a}
[/tex]
There will be 4 mutually orthogonal eigenvectors. For reasonable matter, one will be timelike, and the others spacelike. Now the eigenvalue associated with the timelike eigenvector is just the (negative of) the density [itex]\rho[/itex]. The eigenvectors associated with the three spacelike eigenvectors are called the principle pressures (or stresses). A perfect fluid is defined to be an object where all principle pressures are identical. Calling this [itex]p[/itex], it's easy to show that the only way of writing a stress-energy tensor with these properties is
[tex]
T^{a}{}_{b} = \rho u^{a} u_{b} + p (\delta^{a}_{b} + u^{a} u_{b} )
[/tex]
Incidentally, the four-velocity [itex]u^{a}[/itex] is the timelike eigenvector.
Oct21-06, 02:41 AM   #9
Quote by pmb_phy
Best wishes
Pete
Thanks for contacting the author. I think it is very clear what he means (how could he explain it better ?). I'm curious about the opinion of the other experts (Pervect, ..)
Oct21-06, 04:34 AM   #10
Recognitions:
I'm wondering about Hartle's approach. Is he perhaps deriving the stress-energy tensor from a Lagrangian density formalism? If he is, this might give some insight into his comments. There's nothing in particular in his resonse to indicate if he is doing this - but that would be one logical way to define energy and momentum.
The stress-energy tensor one gets via this procedure isn't unique, one can add a divergence term to it. I believe that this divergence term is usually used to make the tensor symmetric and gauge-invariant, which doesn't always happen automatically.
http://bolvan.ph.utexas.edu/~vadim/C...works/hw01.pdf
talks about this some.
Oct21-06, 07:51 AM   #11
Quote by notknowing
Yeah. I see what he means now.
Pete
Oct21-06, 08:34 AM   #12
Recognitions:
Gold Membership Gold Member
Quote by pmb_phy
Jim Hartle
Best wishes
Pete
This is clear enough. In flat spacetime there are obviously no terms proportional to the local curvature. In any given coordinate system you will have a bunch of zeros there. But in curved spacetime - curved spacetime whise curvature is a function of this very tensor! - those zeros will become non-zero amounts that depend on the curvature. And you can't tell from the flat version of the tensor which zeros are going to do what.
But look, the tensor multiplication with the metric tensor is what goes through, just replacing Minkowski's diagonal metric with the fiull tensor of pseudo-Riemannian geometry. That will automatically fix the energy-momentum tensor.
Oct21-06, 08:51 AM   #13
Quote by selfAdjoint
We must have posted at the same time because I had already posted that I understood what the author meant. Thanks anyway selfadjoint.
Aplication of the metric tensor to the stress-energy-momentum tensor will not change the tensor itself. Only the components in a given coordinate system. It can change the type of tensor though and perhaps this was what you were thinking. But normally we assign the same name to the tensor A^ub as we do to A^u_v.
Best wishes
Pete
Oct21-06, 09:11 AM   #14
Quote by pervect
I also guess that Hartle is working with the Lagrangian density formalism. After reading the various comments, I'm not sure what to think now. Is it the Lagrangian formalism only which leads to the ambiguity, while other approaches lead to a unique stress-energy tensor ?
Oct21-06, 11:06 AM   #15
Recognitions:
Quote by notknowing
Even if you just take the point of view I outlined (with eigenvalues/vectors), there can still be some ambiguity. I showed how to define the 4-velocity, density, principle pressures, etc. That's pretty much fixed.
But that may not completely specify the stress-energy tensor. For example, you might want to find the equations of motion of the system from [itex]\nabla_{a} T^{ab}=0[/itex]. The perfect-fluid expression isn't quite sufficient for that. There are more variables that you need to solve for than there are equations. So you need to bring in an "equation of state" relating the pressure to the density. More complicated materials naturally need much more involved constitutive relations, and it may be natural to write these in terms of (say) the Riemann tensor, some potentials, etc.
You also might not want to decompose the stress-energy tensor into a density and pressures. For example, it would look a little odd to describe long-range fields in that way (despite that it's possible). The "natural variables" which characterize the system may be related to the stress-energy tensor in a complicated way.
In general, most people prefer to define the behavior of an object through a Lagrangian formalism. You get a different material for each action you write down, but there isn't necessarily a unique way of going from a flat-spacetime Lagrangian to a curved-spacetime one.
Oct21-06, 06:38 PM   #16
Recognitions:
[QUOTE=notknowing]
"the principle of minimal coupling"? why not "maximal coupling" (is there such a thing? )
I just can not understand the reason for inventing such confusing name for "the equivalence principle"
This statement is a rephrased version of the equivalence principle which states:
Every non-inertial frame is locally equivalent to some gravitational field. Or, At every point in an arbitrary gravitational field one can choose a locally inertial frame in which the laws of physics take the same form as in SR.
So, the "comma-goes-to-semicolon" rule is the mathematical form of the equivalence principle.
Note that,
[tex]\eta_{ab} \rightarrow g_{ab}[/tex]
is nothing but a switching between referece frames. These frames are connected by smooth transformations. So, as long as the two metrics have the same signature, the "generalization"
[tex]T^{ab..}(\eta) \rightarrow T^{ab..}(g)[/tex]
is unique for any tensor T.
Gravity enters through, and only through, the covariant derivative of curved spacetime (i.e. spacetime with non-vanishing Riemann tensor). Here, in applying the
[tex]\partial_{a} \rightarrow \nabla_{a}[/tex]
rule of equivalence principle, one, sometimes, encounters factor-ordering problems.
I believe, the MTW explains the "Equivalence principle as a tool to mesh nongravitational laws with gravity". It also gives "rules-of-thumb" which resolve most factor-ordering problems. Anyway, one only needs to remember that interchanging covariant derivatives produces terms that couple to curvature.
The equivalence principle has stood the test of time both theoretically and experimentally.
regards
sam
Oct21-06, 07:59 PM   #17
Recognitions:
Quote by samalkhaiat
Minimal coupling is not the same as the equivalence principle. It says that the form of an equation that people like to write down in SR is essentially the same as the form of that equation in GR. In other words, the equations involve the curvature as little as possible. This is just a rule-of-thumb.
The equivalence principle is also a rule-of-thumb (there is no precise nontrivial definition which is known to be correct). But it has so much historical baggage associated with it that it means different things to almost everyone. Some of those are similar to minimal coupling, but many are not. It's better to use a term which everyone agrees on.
"Every non-inertial frame is locally equivalent to some gravitational field" is only true if you can ignore all derivatives of the metric of order 2 or higher. That's often possible, but it certainly isn't universal.
Thread Closed
Thread Tools
Similar Threads for: stress-energy tensor in curved spacetime
Thread Forum Replies
the stress energy tensor again Special & General Relativity 9
Stress-energy tensor of a wire under stress Special & General Relativity 178
Stress-Energy Tensor Special & General Relativity 17
Energy Tensor Divergences and Gauss / Stokes in Curved Spacetime General Physics 0
I can't see how stress-energy tensor meets the minumum tensor requirement Special & General Relativity 4
