How High Must a Propeller Fall to Match Its Rotational Energy?
An airplane propeller with a length of 2.08 m and a mass of 117 kg is rotating at 2400 rev/min, resulting in a rotational kinetic energy of 1.33x10^6 J. To find the height it must fall to match this energy, the equation mgh = K2 is applied, where h is the height, m is mass, and g is gravitational acceleration. The initial calculation yielded a height of 1159 m, but the answer was incorrect due to unit conversion errors, as the required answer was in kilometers. The discussion highlights the importance of unit consistency in physics calculations. Ultimately, the correct height in kilometers should be calculated from the initial energy value.
rleung3
An airplane propeller is 2.08 m in length (from tip to tip) with mass 117 kg. The propeller is rotating at 2400 rev/min about an axis through its center. Its rotational kinetic energy is 1.33x10^6 J. If it were not rotating, how far would it have to drop in free fall to acquire the same kinetic energy?
I tried using this equation:
K1 (becomes 0) +U1 = K2+U2 (becomes 0)
since the object would start from rest, K1=0. I will call the height of the object y=h, and the point at which it reaches required kinetic energy will be at y=0
U1 = K2
mgh = 1.33x10^6 J
h=(1.33x10^6 J)/(mg)
But that answer is wrong. The computer doesn't give me the right answer, but it says that one is wrong. Any thoughts? Thank you.
Ryan
Looks right to me. What was the exact answer that you put in?
I put in 1159 m (1.33x10^6 J)/(117g). It usually leaves room for errors up to 10%.
OOHH! Nevermind..it wanted the answer in km and I put it in m. Stupid me!
