| Thread Closed |
Laplancian vector? |
Share Thread | Thread Tools |
| Oct28-06, 09:02 PM | #1 |
Laplancian vector?
In http://mathworld.wolfram.com/Laplacian.html under
'Using the vector derivative identity' It has that forumula for the laplacian of a vector. In cartesian coords it can be derived but I read in books that the this laplacian on vector fields that are not cartesian can only be defined. But why don't they define it in other systems as the scalar laplacian (wrt to their own coords systems) of each components of their vector field? It would make more sense wouldn't it? |
| Oct29-06, 10:51 AM | #2 |
Recognitions:
If (u,v,w) is an arbitrary curvilinear coordinate system, then:
[tex]\nabla^2 \vec A = \nabla^2 (\hat e_u A_u + \hat e_v A_v + \hat e_w A_w ) = \nabla^2 (\hat e_u A_u) + \nabla^2 ( \hat e_v A_v) + \nabla^2 ( \hat e_w A_w )[/tex] In a system where the basis vectors depended on position, there will be extra terms, eg: [tex] \nabla^2 (\hat e_u A_u) = \hat e_u \nabla^2 A + 2 (\nabla \cdot \hat e_u) \nabla A_u + A_u \nabla^2 \hat e_u [/tex] If you're asking why we don't just define the Laplacian so that: [tex]\nabla^2 \vec A = \hat e_u \nabla^2 (A_u) + \hat e_v \nabla^2 (A_v)+ \hat e_w \nabla^2 (A_w)[/tex] the reason is that the answer we'd get would depend on the coordinate system we're using, which is something we don't want. |
| Oct30-06, 04:59 AM | #3 |
| Oct30-06, 10:21 AM | #4 |
Recognitions:
Laplancian vector?
I don't know what you mean. All that equation used was the expansion of A in the (u,v,w) coordinate system and the linearity of the laplacian.
| Oct30-06, 04:53 PM | #5 |
I think my question arose from a misunderstanding on my behalf. Is it the case that the equation (highlighted in post 3) is the first step in solving the vector Laplacian of A. The next step is to apply the definition of a Laplacian vector on each component, like breaking a complicated problem into smaller bits but applying the same principle, which in this case is the definition of a Laplacian vector.
When you say the answer would depend on the coord system, do you mean that if I got in spherical coords, A=r(wrt r coord) than in cartesian, it should be A=(x,y,z). But this doesen't always happen if you (hypothetically) define the Laplacian as you have done in the last equation of post 2. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Laplancian vector?
| Symbolic represenation of the unit vector and the vector | General Math | 11 | ||
| Deriving Vector and position vectors from Force vector | Introductory Physics Homework | 3 | ||
| calculate vector with known magnitude along the direciton given by another vector | General Math | 3 | ||
| I thought w(f) where w=dual vector f=vector is Reals? | Differential Geometry | 1 | ||
| tagent vector and vector field difference | Differential Geometry | 6 | ||
