How Much Energy Is Needed to Freeze Water and Melt Ice Through Friction?
The discussion focuses on the energy required to freeze water and melt ice through friction. To convert 35.0 kg of water at 20.0°C to ice at 0°C, 11,690 kJ of energy must be removed, calculated using the formula Q = m * L, where L is the specific latent heat of fusion (334 kJ/kg). When a block of ice slides with an initial speed of 6.50 m/s, it generates 1,126.25 J of kinetic energy, resulting in the melting of 0.0034 kg of ice. To completely melt the ice, the block must be projected at a speed of 11.6 m/s, derived from the energy needed to freeze the water.
  • Understanding of thermodynamics principles, specifically latent heat.
  • Familiarity with kinetic energy calculations (KE = 1/2 * m * v^2).
  • Knowledge of specific latent heat of fusion for water (334 kJ/kg).
  • Ability to manipulate algebraic equations for energy calculations.
  • Study the concept of latent heat and its applications in phase changes.
  • Learn more about kinetic energy and its transformation into thermal energy.
  • Explore the relationship between speed and energy in frictional contexts.
  • Investigate real-world applications of thermodynamics in engineering and physics.
Students studying physics, particularly those focusing on thermodynamics and energy transformations, as well as educators looking for practical examples of energy calculations in real-world scenarios.
tbwtki
Help Please!
Hello Could someone help me with this problem? thanks
Part
A:
A container holds 35.0 kg of water at 20.0 C. HOw much energy must be removed from the water to turn it completely into ice at 0 C?
Part
B:
The block of ice is projected a cross a surface at an initial speed of 6.50m/s. While it is sliding across the surface, the friction force casues the ice to melt. After the block has stopped sliding and come to rest, how much ice has melted? Assume that all tof the internal energy transformed by the frction force goes into the ice -- none goes into the surface.
C:
With the same assumptions as in part (b), with what speed would the block of ice have to be projected inorder to completely melt it due to friction?
I recognize this question. It's from an AP "B" exam from the early 90's.
First off, remember that heat is energy. One formula (Q = c m deltaT) will tell you how much heat must be removed to get the water to zero degrees. A second formula (Q = mL) will tell you how much heat must be removed to turn that zero degree liquid water into zero degree ice water.
Second part: kinetic energy of ice is assumed to turn into heat. HOw much KE? use that amount in that second formula above to see how much mass of ice melts.
Third. HOw much total KE is needed to melt all the ice? the same as the energy needed to turn the water into ice (second half of the first part). What speed corresponds to that amount of KE?
Hello! I can definitely assist you with your energy physics homework. Let's take a look at each part separately.
Part A: To turn water into ice, we need to remove energy from it. The amount of energy required can be calculated using the equation Q = m * L, where Q is the energy, m is the mass, and L is the specific latent heat of fusion (for water, this is 334 kJ/kg). So, in this case, we have Q = 35.0 kg * 334 kJ/kg = 11,690 kJ. Therefore, 11,690 kJ of energy must be removed from the water to turn it into ice at 0 C.
Part B: In this part, we need to determine how much ice has melted after the block has come to rest. To do this, we first need to calculate the kinetic energy of the block using the equation KE = 1/2 * m * v^2, where KE is the kinetic energy, m is the mass, and v is the speed. So, in this case, we have KE = 1/2 * 35.0 kg * (6.50 m/s)^2 = 1,126.25 J. This is the amount of energy that goes into melting the ice. Now, we can use the equation Q = m * L to find the mass of ice that has melted. So, Q = m * 334 kJ/kg, and we know Q = 1,126.25 J. Solving for m, we get m = 1,126.25 J / 334 kJ/kg = 0.0034 kg. Therefore, 0.0034 kg of ice has melted due to friction.
Part C: Finally, we need to find the initial speed at which the block of ice would have to be projected to completely melt it due to friction. Using the same equation as before, Q = m * L, we can solve for v by plugging in the values we know. So, 11,690 kJ = m * 334 kJ/kg, and we know m = 35.0 kg. Solving for v, we get v = √(11,690 kJ / 35.0 kg * 334 kJ/kg) = 11.6 m/s. Therefore, the block of ice would need to be projected at an initial
  • · Replies 17 ·
