Register to reply
VFD and Motor Performance
by joshman
Tags: motor, performance
Share this thread:
joshman
#1
Nov16-06, 11:49 PM
P: 2
Im a HVAC contractor/designer. Im looking to install a fan unit with a VFD. This is 3 phase, 60HZ, 460 volts, 40HP AC motor.
Im trying to create a "system curve" like a fan curve that would show the cfms at various frequency settings being changed by the VFD. I can reiterate or integrate my ductwork calculations for multiple rpms of a fan curve. And I know that RPM theoretically varies linearly with frequency, but im wondering how much or much less, motor slipage will occur at lower frequencies. you see my question is: If 60hz=1750 RPM does 30Hz really = 875 RPM? Im not speaking theoretically.
Maybe someone has seen a motor curve of rpm vs Hz?
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
RainmanAero
#2
Nov17-06, 01:00 AM
P: 83
Hi joshman,
Quote Quote by joshman
Well, first of all, are you aware that for a VFD you really need to keep the Volts per Hertz (V/Hz) ratio constant in order to keep motor torque constant? So in your example, you will want to change the voltage to 230V when you bring the frequency down to 30 Hz. If you do not, you will change the total torque output, and this will affect your slippage.
Well, the exact equation (ignoring slippage) also includes the number of poles in the motor: Speed (RPM) = 120*freq/npoles. The following page has a good summary of VFDs and an estimate for slippage, as well as some info on typical means for controlling VFDs:
http://www.joliettech.com/what_is_a_...ency_drive.htm
Did this help? If you like, we can discuss the specifics of the mass flow rate... as this is really a question of the fan's aerodynamic efficiency at varying speeds and fan pitch.
Rainman
Register to reply
Related Discussions
Pipeline performance Computing & Technology 1
3 Volt DC Motor Performance Graphs General Engineering 1
Performance: OO vs Procedural (C++ vs C) Computing & Technology 5
Performance in F1 cars Mechanical Engineering 4
