Calculating Electric Field of a Solid Sphere with Uniform Charge Density
  • Thread starter Thread starter paul11273
    Field
The discussion centers on calculating the electric field of a solid plastic sphere with a uniform charge density. The user, paul11273, initially calculated the charge density as 4.6 x 10^-5 C/m^3 and the total charge within a radius of 0.05m as 1.91 x 10^-7 C. However, the correct approach involves using Gauss's law to express the electric field at a distance of 15cm (3R) in terms of the electric field at 5cm (R), leading to a simplified calculation. The final electric field result at 15cm is determined to be 7.63 x 10^4 N/C, contingent on correctly identifying the total charge within the sphere.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with electric field calculations
  • Knowledge of charge density and its implications
  • Basic arithmetic and algebra for physics calculations
  • Study the application of Gauss's Law for spherical charge distributions
  • Learn how to derive electric fields from charge densities
  • Explore the concept of electric field lines and their significance
  • Practice solving problems involving uniform charge distributions
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in mastering electric field calculations for charged objects.
paul11273
Here is a HW question that I have been wrestling with. Hopefully I have gone about solving it correctly. There is no answer in the back of the text to check my result against. Can anyone have a look and confirm?
Question-
"A solid plastic sphere with radius of 10.0cm has a charge with uniform density throughout it's volume. The electric field 5cm from the center is E=86.0 kN/C radially inward. Find the magnitude of the electric field 15cm from the center."
First I figured I needed to find the charge density. I set EA=qr/e0 ,where e0 is permittivity of free space and qr is total charge at radius of .05m given in the problem. I get to E=pr/3e0 where I am using p as charge density.
I solved for p with the given E and r, so p=4.6*10^-5 (C/m^3).
Next, I found the total charge within the .05m sphere with Q=pV. I got 1.91*10^-7 (C).
Lastly, I used E=ke(Q/r^2) to find the electrical field at radius=.15m. My final result is E=7.63*10^4 (N/C).
Can anyone tell me if I am correct? If not, where did I go wrong? Any help would be appreciated. I feel like I may have done too much work, there is probably a shorter way to the answer.
Thanks.
I didn't check your arithmetic, but your equation is correct.
You need to find the total charge, which extends to radius = 0.1m.
If you had the correct "Q", that method would work.
Here's how I would do this problem. First, I would express all distances in terms of the first radius given, R = 0.05. Thus the radius of the sphere of charge would be 2R; the distance at which you are to find the field would be 3R.
Then I'd apply Gauss's law find the charge density (like you did), but I would express it in terms of the field given (call it E1 and R.
Then I'd find the total charge (like you intended to do) for the sphere of radius 2R. Don't plug in numbers, just get an expression.
Then I'd use Gauss's law again to find the field at a distance of 3R, using the Q I just found.
Do it this way and you'll find that things cancel and you get a simple expression of the field at 3R in terms of the original field at R. The moral: don't be in a rush to plug in numbers and do arithmetic.
Thanks, Doc Al, for taking the time to review my work.
After checking my work I realize that I actually did find the charge of the .1m radius, not the .05m. I must have made an error typing it in. Good catch though.
I will try reworking this problem with your method of using R, 2R and 3R. I understand the concept, but I won't really get it until I work it all out on paper.
Thanks again.
