Analyzing Electrical Circuits: True and False Statements
  • Thread starter Thread starter bob123
    Circuits
The discussion revolves around analyzing electrical circuits, specifically comparing the behavior of three circuits with identical batteries and resistors. The original poster presents a list of statements regarding power dissipation and current flow in these circuits, seeking clarification on their validity.
  • Exploratory, Assumption checking
  • The original poster attempts to evaluate the truth of several statements based on calculations involving voltage and resistance. Some participants suggest that using algebra instead of specific values might simplify the analysis.
Participants have provided feedback on the original poster's calculations, indicating agreement on the correctness of the evaluations. However, there is uncertainty regarding the interpretation of one statement, leading to speculation about its validity. The discussion remains open as the original poster awaits further clarification from their professor.
Participants note that the interpretation of the statement regarding current through a resistor in circuits A and B may depend on whether it refers to individual resistors or equivalent resistance, highlighting potential ambiguity in the question.
bob123
So I have the following homework question about electical circuits. There's three different circuits shown: Circuit A is just a battery hooked up to a single resistor. Circuit B is a battery hooked to two resistors in series. Circuit C is a battery hooked to two parallel resistors. All the circuits are closed and all the batteries and resitors are identical. There's a list of five statements and we have to say which are true and which are false.
1. The total power dissipated in circuit C is twice the total power dissipated in circuit B.
2. The current through a resistor is the same in circuits A and C.
3. The voltage across a single resistor in circuit C is twice the voltage across a single resistor in circuit B.
4. The power dissipated in circuit A is twice the power dissipated in circuit B.
5. The current through a resistor is the same in circuits A and B.
I worked through this problem assuming the voltage supplied was 10 V, and the resistance of each resistor was 2 ohms. This is what I got (correct me if I'm wrong anywhere, and I'm sure I am):
1. Total power dissipated in C is 100 W (10 V total * 10 A total), total power dissipated in B is 25 W (10 V total * 2.5 A total). So 1 is false. I'm not sure if I'm doing the total power dissipated for Circuit B right.
2. The current through circuit A is 10 V / 2 ohms = 5 A. In Circuit C, the current through each resistor is 10 V / 2 ohms = 5 A. True.
3. The voltage across a single resitor in C is 10 V (since voltage remains the same across a parallel circuit, right?). The voltage across a single resistor in B is 5 V (2.5 A * 2 ohms). True.
4. Power dissipated in A is 50 W (10 V * 5 A). Again, I'm not sure if I'm figuring this right, but the total power dissipated in B is 25 W (10 V total * 2.5 A total). True.
5. Current through the resistor in circuit A is 5 A (10 V / 2 ohms). Current through a resistor in circuit B is 2.5 A (10 V / 4 ohms). False.
I tried this answer and the computer said it was wrong. Am I doing something wrong, or is this just an error with the online assignment?
If you're comfortable with algebra, there's no reason to substitute values in for voltage and resistance. That said:
1. you are correct
2. correct again
3. correct again
4. correct again
5. correct again
So I think you've got them all right. So, either we both messed up or the program is wrong. Let us know if you need anything clarified.
I can't stand algebra, so I just used real numbers. I e-mailed the prof about it, unfortunately he's out of town til Tuesday. That's why I asked about it here. Thanks for double checking these.
The only problem I see is number 5 which can be argued as true. The question as you have it stated is "The current through a resistor is the same in circuits A and B." The key part of the question is "through a resistor." This may mean that only one resistor in B (2 ohms) is used, not the equivalent resistance (2ohms + 2ohms). We find 10V/2ohms = 5 amps which equals the current in A.
Of course this is only speculation, but worth a try. Hope it helps.
I got:
1. F
2. T
3. T
4. T
5. F
  • · Replies 42 ·
