What type of clock is capable of measuring periods of milliseconds?
  • Thread starter Thread starter swain1
    Measuring
To measure periods of milliseconds, a clock with a frequency significantly higher than the signal frequency is required, typically around 100 times the signal frequency for accurate measurements. Crystal oscillators operating in the 10MHz-100MHz range are commonly used for this purpose. A stopwatch is not suitable for measuring milliseconds due to its lower accuracy. Instead, frequency counters are the appropriate instruments for measuring frequency and period accurately. These devices utilize high-frequency clock signals to enable precise timing measurements.
swain1
Hi,
I have been asked to research two types of clock. The first to measure periods of nanoseconds and the second, milliseconds. Obviously I have talked about atomic clocks first but what clock can measure periods of milliseconds?
Cheers
Millisecond clocks are easier than nanosecond clocks. You would typically have an accurate crystal oscillator running in the 10MHz-100MHz range, and enable a counter with the signal that you want to measure the period of. Does that make sense?
Yes it makes perfect sense but what is the type of clock called? Could a stopwatch working under this principle measure milliseconds?
No, a stopwatch is too slow. You need a clock that is many times the signal to be measured, in order to get good accuracy on the measurement. You need approximately 100x the signal frequency, in order to get 1% accuracy in the period measurement, right?
So a 100x clock for a 1ms signal (with a frequency of 1kHz) would be 100kHz, which is easy. More likely you would use a crystal clock oscillator module to generate a 10MHz clock, and feed that into the digital counter string that I mentioned.
Instruments called "frequency counters" are used to make the frequency and period measurements that you are asking about. Here is a wikipedia.org page with basic info on them. You can google frequency counter for more links and info.
http://en.wikipedia.org/wiki/Frequency_counter
