Tension on a Rope with Variable Mass Distribution
  • Thread starter Thread starter Solidmozza
    Mass Rope Tension
The discussion focuses on calculating the tension in a vertical rope with a block attached, under the influence of a constant upward force. The problem involves applying Newton's Second Law to both the entire system and a specific point on the rope. The solution derives the tension at a distance 'x' from the top of the rope, leading to the formula T = F[M + m(1 - x/L)]/(M + m). Key points include understanding the forces acting on the system and how to express the mass of the rope segment at point 'x'. The clarification of the approach helps in grasping the underlying physics of the problem.
Solidmozza
A block with mass 'M' is attached to the lower end of a vertical, uniform rope with mass 'm' and length 'L'. A constant upward force 'F' is applied to the top of the rope, causing the rope and block to accelerate upward. Find the tension in the rope at a dstance 'x' from the top end of the rope, where 'x' can have any value from 0 to 'L'.
Newton's Second and Third Laws.
I'm a bit confused on this question. I've tried breaking the problem up into three parts - one for the block mass 'M', one for the top of the rope and one for a point 'x' on the rope - but I can't seem to get it to work. The actual constant force there is annoying too - for the top of the rope I have a force acting downwards of (m+M)g, and an upwards force that is greater than that of 'F', but I don't know how I can equate etc. The answer is F[M+m(1-x/L)]/(M+m) but I want to know why.
Thanks in advance.
Try to apply Newton's 2nd law to the whole system in order to find the acceleration. Then try to look at an element of the rope at a distance x from the top end of the rope, and try to express the mass of that element somehow. Then apply Newton's 2nd law again. I don't have the time to write it down and check if it's right, though.
Ah sweet! That seems so obvious now - Silly me!
First, we consider the point on the highest point of the rope (ie where x=0). There are only 2 forces acting here: the combined weight force of the rope and the block, and the upward force. Since the whole thing is accelerating, we use Newtons second equation of motion... F=ma, now m = M+m (mass of rope+block), so we get a = F/(M+m). Now we take the point 'x' on the rope. Am I right in saying that there are only two forces here - the tension force due to action-reaction pairs which acts upwards, and the weight force? (It seems to work mathematically...). So we know that the mass of the section of the rope + block =.. M+M[(L-x)/L]. Thus again we use F=ma (although its tension force this time!), giving F= M+M[(L-x)/L] x F/(M+m), which is= F[M+m(1-x/L)]/(M+m) as required.
Thanks for your help :D
Likes Touuka
