Using root test and ratio test for divergence
The series from n=1 to infinity of n(-3)^(n+1) / 4^(n-1) diverges. The Ratio Test was applied, leading to the limit of ((n+1)*(-3)^(n+1)/4^n) / (n * (-3)^n / 4^(n-1)), which simplifies to -3, confirming divergence. The Root Test was also attempted with the limit of -3*n^(1/n) / 4^((n-1)/n), but confusion arose regarding the limit of (n-1)/n as n approaches infinity, which equals 1.
  • Understanding of series convergence and divergence
  • Familiarity with the Ratio Test for series
  • Knowledge of the Root Test for series
  • Basic calculus concepts, including limits
  • Study the application of the Ratio Test in depth
  • Explore the Root Test and its conditions for convergence
  • Learn about L'Hospital's Rule and its use in limit evaluation
  • Investigate other convergence tests, such as the Comparison Test
Students studying calculus, particularly those focusing on series convergence, as well as educators seeking to clarify convergence tests in mathematical analysis.
superdave
Does this series converge or diverge?
Series from n=1 to infinity n(-3)^(n+1) / 4^(n-1)
Okay, I've tried it both ways.
Ratio test:
lim n --> inf. ((n+1)*(-3)^(n+1)/4^n) / (n * (-3)^n / 4^(n-1))
Now, that doesn't appear to simplify in anyway that would make using l'hospital's rule possible to find the limit.
Root test:
lim n --> inf. of -3*n^(1/n) / 4^((n-1)/n)
That bottom part throws me off.
Why does it through you off? What is the limit of (n-1)/n as n goes to infinity?
Ratio test:
Seriously? You are aware, are you not, that (-3)^(n+1)/(-3)^n= -3? The (4^n part is just as easy! You should not need L'Hospital's rule.
Root test:
