Thread Closed
2 equations, 2 unknowns
Share Thread Thread Tools
Mar20-07, 06:02 PM   #1
I can't remember how to solve these equations like this one. I need to solve for each variable. I'm not sure I've ever known how to do this.
-720 + Tab*cos(36.8699) + Taf*cos(20.556)
660 + Tab*sin(53.1301) + Taf*sin(69.444)
I need to solve for both Tab and Taf. This is possible, right?
2. Relevant equations
3. The attempt at a solution
Don't even know where to start...need help!
Thanks,
Brad
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar20-07, 06:10 PM   #2
These are not equations, there are no equal signs. Thus they cannot be solved. But, if they were to have equal signs, sin (53.1301) just represents a number right? If you 53.1301 is in degrees and not radians (very likely) then sin (53.1301)= [tex]0.8[/tex]
To solve two equations in two unkowns, there are a few ways. Perhaps the easiest is to solve for one variable in one of the equations in terms of the other equation and then plug that into the other equation.
So lets say you have two equations in y and x such as:
3x+y=5
y+5x=2
You could solve the second one for y.. y=2-5x right?
now plugging it into the first one you get
3x+2-5x=5
-2x=3
x=-2/3
Now just plug x=-2/3 into the other equation and solve for y. Easy.
Mar20-07, 06:44 PM   #3
Ok so is this right then....
Solving second equation for Tab
Tab = =(-Taf(.936) - 660)/.8
Then insert back into equation 1....
-720 - Taf(.936) - 660 + Taf(.936) = 0
These are all equal to zero, forgot to add that in....and yes, they are degrees.
If that is right, I can't get an answer to come out.
Mar20-07, 08:58 PM   #4
Mentor
Check your signs. The second equation gives Tab*sin(53.1301) =- Taf*sin(69.444)-660. Plug this into the first and you get {Taf/sin(53.1..)}*[-sin(69.444)-660]*cos(36.8699) + Taf*cos(20.556)=720.
I suspect you are missing a minus sign.
Thread Closed
Thread Tools
Similar Threads for: 2 equations, 2 unknowns
Thread Forum Replies
Circuit design, 2 equations, 3 unknowns... Engineering, Comp Sci, & Technology Homework 7
3 equations, 3 unknowns, how do i solve!!!? Calculus & Beyond Homework 10
2+ unknowns Introductory Physics Homework 4
unknowns Classical Physics 8
two equations, two unknowns General Math 5
