Thread Closed
Power required to rotate the system
Share Thread Thread Tools
Apr13-07, 04:56 AM   #1
Thumbs up
Hai
This is first post of mine regarding steady state power requirement.
Since i am involving the power requirement project I am posting the question in simple way as follows.
Drive & driven both two pulleys are connected by timing belt
Drive pulley diameter is 100mm(face width25mm) Pulley is bearing supported
Driven pulley is 300mm(face width 25mm) same bearing supported in the bore.
Speed 500mm
Mass of drive pulley is say 3Kg driven pulley is 20 kg
Both pulley is supported by bearings.Bearing diameter is (drive pulley mean dia 40mm) Bearing diameter (driven pulley mean dia is 75mm)
(Neglect the acceleration torque next phase we can discuss this)
What is the power requirement of the above system?
Assume no load condition(otherwise if you thought that no sense in this add load in driven pulley as 100kg)
Thanks in advance
Prakash
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr13-07, 06:26 AM   #2
Recognitions:
If it's steady state theoretically there's no load required. In reality, the only load is then the required power to overcome motor inefficiencies, pulley windage, belt and bearing friction. Your speed is 500 rpm (you have a type-o in your post there)?
Apr15-07, 10:36 PM   #3
Quote by FredGarvin View Post
Thank you Mr.Fred garvin
Yes speed unit there is typing error.ok I have understand your reply but my doubt is how to include the belt efficiencey or tension without knowing the power any suggestions regarding this,Any typical calculations.....will be greatly appereciated.
Thanks in advance
Prakash
Thread Closed
Thread Tools
Similar Threads for: Power required to rotate the system
Thread Forum Replies
Why is the solar system, & galaxies seemingly rotate on a 2-D plane? Astrophysics 10
Power required to operate a ski tow Introductory Physics Homework 3
Urgent help required for F.B.D of servo system please Engineering, Comp Sci, & Technology Homework 0
Required power for Si evaporation? General Physics 4
Power required Introductory Physics Homework 2
