How does the shape of a lens affect focal lengths?
  • Thread starter Thread starter jst81161
    Focal
The shape of a lens significantly influences the convergence of light rays and their respective focal points. Inner rays typically converge at a shorter focal distance compared to outer rays, which require more bending due to the lens's curvature. This discrepancy arises from the ideal versus actual shapes of lenses, affecting how light is refracted. Understanding these differences is crucial for grasping lens design and optical performance. The discussion highlights the importance of lens geometry in determining focal lengths.
jst81161
Why do two outer rays converge to a different focal point than the inner rays?
The distance to the focal point of the inner rays is shorter than the outer rays, the light has to bend a lot more for the outer rays
I don't think you've really hit the nail on the head. Think about the ideal shape of a lens and the actual shape of a lens.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
