Understanding the Limitations of WKB Approximation in One-Dimensional Problems
InGaAsP
Hi all
I have a question about WKB approximation
Why is it that WKB method can be applied only to problems that are one dimensional or those which can be reduced to forms that are one dimensional ones?
any help is deeply appreciated
InGaAsP said:
Hi all
This is not quite correct. The one-dimensional WKB is widely used because you can have explicit approximate solutions. In many dimensions, there are no such explicit solutions. The analog of WKB approximation in many dimensions is the approximation of geometric optics (or eikonal approximation). This approximation can be applied to a wave equation in many dimensions, and you get a Hamilton-Jacobi equation for the "eikonal" function.
It works like this. Suppose you have a wave equation, let's write it symbolically as Wave(\psi(x))=0, where "Wave" is a differential operator and \psi(x) is a function describing the wave; x is a multidimensional position vector. You would like to consider solutions \psi(x) that look like quickly oscillating waves. So then you write the ansatz, \psi=\exp(\imath \lambda \Omega(x)), where \Omega is a new unknown function, representing the phase of the oscillation, and \lambda is a large constant (it's large because you want the wave to oscillate quickly). Then you substitute this ansatz into the wave equation and keep only terms of highest order in \lambda. You get a nonlinear equation for \Omega(x), which looks like the Hamilton-Jacobi equation. The function \Omega is called the 'eikonal' but it's just the phase of the wave. This function can be interpreted as the action of a particle, as in the usual Hamilton-Jacobi formalism in mechanics. So in this way you can visualize propagation of waves as motion of particles along "rays".
In one dimensions, you do this and get an ordinary differential equation of first order for the eikonal \Omega. So this can be solved and you get an explicit formula for the eikonal. In many dimensions, you can't solve it symbolically, so you just kind of say "grrr..." but at least the approximate solution exists and looks like a wave propagating in straight lines.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
