1.) Net electric field and 2.) Maximum electric field from centre of a ring
The discussion revolves around two problems related to electric fields. The first problem involves determining the point along an axis where the net electric field from two fixed charges is zero. The second problem concerns finding the distance from the center of a uniformly charged ring where the electric field is maximized.
  • Mixed
  • Participants explore the conditions under which the net electric field can be zero between two charges, questioning the assumption that the zero field point lies between them. They discuss the regions to consider for the electric field analysis.
  • In the second problem, participants discuss the differentiation of the electric field equation and the implications of having two unknowns. Some suggest that the constant charge will not affect the final outcome.
  • There is confusion regarding the signs of the electric fields based on the positions relative to the charges, with participants clarifying how the direction of the electric field relates to the sign of the charges.
Participants have provided insights into the assumptions regarding the location of the zero electric field point and the differentiation process for the electric field of the ring. There is ongoing exploration of the implications of these assumptions, and some participants have offered clarifications on the signs of the electric fields.
Participants are navigating the complexities of electric field calculations, including the need to consider multiple regions for the first problem and the challenge of differentiating the electric field equation in the second problem. There is an acknowledgment of the need for clarity on the assumptions made in both scenarios.
irnubcake
1. Problem1 statement, all variables and given/known data
In the figure particle 1 of charge q1 = -8.13q and particle 2 of charge q2 = +3.63q are fixed to an x axis. As a multiple of distance L, at what coordinate on the axis is the net electric field of the particles zero?
http://img201.imageshack.us/img201/4669/netfieldzeromy7.gif
Electric Field = k|q| / r²
The attempt at a solution
Since it's a point between the two charged particles, let x = the distance between q1 and that point, so the distance between the point and q2 = L - x
http://img157.imageshack.us/img157/990/netfieldzero2xj8.gif
The net electric field = 0,
so -(Electric field due to q1) + (Electric field due to q2) = 0
E1 is negative because q1 is negative, E2 vice versa.
-( k|-8.13q| / x² ) + ( k|3.63q| / (L - x)² ) = 0
Cancelling, etc gives:
4.5x² - 16.26Lx + 8.13L² = 0
quadratic formula gives: x = 0.6L or 3.01L
I got it wrong, I'm also confused about the sign of the electric fields but the quadratic formula won't produce a real solution if both fields were negative or positive.
1. Problem2 statement, all variables and given/known data
Charge is uniformly distributed around a ring of radius R = 2.41 cm and the resulting electric field is measured along the ring's central axis (perpendicular to the plane of the ring). At what distance from the ring's center is E maximum?
Electric Field of Ring = (kqx) / ( (x² + k²) ^ (3/2) )
I attempted to differentiate the equation with respect to x and put E' = 0, but I have two unknowns, x and q, the solution is a real number with no variables.
Problem1
Why do you assume that the point in question is between the two particles? Is that even possible? There are three regions to consider: left of q1, between q1 & q2, right of q2. Step one is to figure out which region is a candidate for containing the zero field point. (In your diagram, draw the directions of the fields from each charge.)
Problem2
irnubcake said:
Electric Field of Ring = (kqx) / ( (x² + ) ^ (3/2) )
That equation should read:
Electric Field of Ring = (kqx) / ( (x² + R²) ^ (3/2) )
You might not know the value of q, but it is a constant. It will drop out of your final equation. Try it!
Ah for the second problem, it ended up as x = R / sqrt(2)
x = 2.41 cm / sqrt(2) = 1.7041 cm
As for the first: http://img515.imageshack.us/img515/4338/netfieldzero3ir5.gif
So I suppose a net field of zero can't be between them. That leaves the left and right regions. Hmmm so maybe the distances: L + x and x. But I'm confused about the signs of the electric fields. Suppose the point is to the right of q2 would E1 still be negative and E2 positive?
Yes. Think of it this way: Since q1 is negative, E1 always points towards q1; so, for x > 0, E1 points to the left and is thus negative. And for x < 0, E1 points to the right and is positive.
Similarly, E2 always points away from q2, a positive charge. For x > L, E2 is towards the right and thus positive.
I don't understant how to take the derivative of the second question. I end up with a huge mess...help?
Just use the quotient or product rule with the chain rule.
For the second one u need not use derivatives. We need the max of
[tex]\dfrac{x}{(x^2+R^2)^{3/2}}[/tex]
Since the expression is odd w.r.t. [tex]x[/tex], we may as well assume [tex]x>0[/tex]. Then the given expression
[tex]=\dfrac{1}{\left(\dfrac{x^2}{x^{2/3}}+ \dfrac{R^2}{x^{2/3}}\right)^{3/2}}= \dfrac{1}{\left(x^{4/3}+ \dfrac{R^2}{x^{2/3}}\right)^{3/2}}[/tex]
Hence, the original expression is going to be maximum where the quantity inside the radical in the denominator, i.e. the quantity [tex]x^{4/3}+ \dfrac{R^2}{x^{2/3}}[/tex] of the last expression is minimum. But by A.M -G.M inequality we get
[tex]x^{4/3}+ \dfrac{R^2}{x^{2/3}} = x^{4/3}+\dfrac{R^2}{2x^{2/3}}+\dfrac{R^2}{2x^{2/3}} \geq 3\sqrt[3]{x^{4/3}\cdot \dfrac{R^2}{2x^{2/3}}\cdot \dfrac{R^2}{2x^{2/3}}}[/tex]
The point is that the condition for equality holds when
[tex]x^{4/3} = \dfrac{R^2}{2x^{2/3}}\quad \Rightarrow\ \boxed{x=\dfrac{R}{\sqrt{2}}}[/tex]
  • · Replies 16 ·
