Finding the Length of PQ in Quadrilateral MNTS and MOPR Using Ratios
  • Thread starter Thread starter lorddarkhelmet
    Desperate
The discussion revolves around finding the length of segment PQ in the similar quadrilaterals MNTS and MOPR. The user has calculated a ratio of 5/4 but is confused about the dimensions and corresponding segments. The lengths from O to N and N to M are given as 16 and 24, respectively, leading to a total length of OM as 40, which contradicts the 5/4 ratio. Clarification is sought on whether PQ refers to PO, as PO corresponds to TN in the other quadrilateral, which has a length of 12. The conclusion suggests that PO should be calculated using the correct ratio based on the established lengths.
lorddarkhelmet
Really Desperate For Help!
Quad MNTS ~ Quad MOPR Find the length of PQ
Big
___
Small
i have done numerous attempts and i can't figure out what to do after i get the ratio of 5/4
I do not see a Q in your diagram. Did you mean PO?
If I am reading your picture correctly, the distance from O to N is 16 and the distance from N to M is 24. That means that the length of OM is 16+ 24= 40. The ratio of any side of the larger quad to the corresponding side of the smaller is 40/24 which is NOT 5/4!
Assuming you do mean PO, PO in quadrilateral MOPR corresponds to TN in quadrilateral MNTS which, according to your diagram has a length of 12. PO must be that length times the ratio.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
