| View Poll Results: what sort of poll is this i dont know | |||
| yes |
1 | 50.00% |
| no |
1 | 50.00% |
| Voters: 2. You may not vote on this poll | |||
| Thread Closed |
Force required on Axel |
Share Thread |
| Apr1-04, 01:47 AM | #1 |
Hello,
This will be a very simple questions for all you pro's out there. I want to know the amount of horsepowers required to start the rotation and maintain a rotation of 20 RPM of an axel which has an arm of 4 mts having a load of 100 kgs at the end of the arm. the dia of tha axel is 1000mm (10 Cm.) and the leangth of the arm as stated above is 4 meters. Please help |
| Apr1-04, 04:42 AM | #2 |
Recognitions:
Technically the answer is 0.
The only thing reason the system will need power to keep it going is because of friction, a variable you don't know. For a second I thought (mv^2)/r would have something to do with it but that force is exerted by the 4m bar and not a motor connected to a shaft. If you give a required torque specification for that given RPM, I can tell you how much power you need. btw, I voted no. |
| Apr1-04, 04:46 AM | #3 |
The final speed isn't important - what you need to decide is the rate at which your device (which sounds more like a centrifuge than an axle) gets to that speed, i.e the (angular) acceleration. Once it's up to speed you just need to overcome friction losses, etc to keep it there.
| Thread Closed |
Similar discussions for: Force required on Axel
| Force Required to Push a Wire | Introductory Physics Homework | 4 | ||
| How much force is required? | Introductory Physics Homework | 3 | ||
| Force required to lift beam | Mechanical Engineering | 2 | ||
| Force Required to lift | Classical Physics | 10 | ||
| How great of a force is required? | Introductory Physics Homework | 13 | ||
