Fourier transform of triangular function
The discussion revolves around finding the Fourier transform of a triangular function defined piecewise. The triangular function is identified as the convolution of two rectangular functions, which is a key concept in Fourier analysis. Participants emphasize the importance of recognizing the endpoints of the triangular function to determine the appropriate rectangular functions for convolution. Despite initial guidance, the user expresses ongoing confusion about identifying the specific rectangular functions related to their example. The conversation highlights the relationship between time domain convolution and frequency domain multiplication in Fourier transforms.
tronxo
Im kind of stuck in one of my signals problems. A triangular function defined as: V(t)= (-A/T)t + A when 0< t< T; V(t)= (A/T)t + A when -T< t< 0; otherwise, the function is 0. I have to find the Fourier transform of this function. Could anyone help me??
A triangle function is the convolution of two rectangle functions. You presumably already know what the FT of a rectangle function is, and you know how convolution in the time domain relates to multiplication in the Fourier domain.
- Warren
thank you for ur time, warren, but I am still having problems with it. The problem is, even though i know, as you say before, that a triangle function is the convolution of two rect functions, i don't know how to identify which rect functions are related to this particular example.
thank you again, Alex
Plot the triangle function, and look at its endpoints. Notice that when you convolve two functions with endpoints (a, b) and (c, d), the resulting convolution has endpoints (a+b, c+d).
- Warren
Thanks again
Alex
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
