Fog: How & Why Does It Form & Disappear?
  • Thread starter daniel_i_l
  • Tags
    Work
In summary, fog is caused by water vapor in the air that condenses into droplets when the air cools down at night. As the temperature rises in the morning, the droplets evaporate and the fog disappears. The same amount of water is present, but in different forms. This explains why fog appears just before sunrise and not in the middle of the night. Fog differs from clouds in terms of height above the ground, but they are both composed of water droplets and vapor. A cloud can exist above a fog bank, but they may have different dynamics and temperatures due to altitude. In some areas, mountains can be engulfed in clouds while nearby towns experience fog.
daniel_i_l
Where I live, sometimes in the morning there's heavy fog just as the sun is coming up but after the sun somes up it all goes away. Why does it get foggy right before the sun comes up and why does the fog disappear shortly after?
Thanks.
Water vapur is held in the air. Water vapour is invisible but when it condenses into water droplets like clouds or 'steam' from a kettle you can easily see it.
The amount of water vapour that air can hold depends on the temperature.
At night as the air is cool, all the water vapour cannot be held n the air and it condenses out into fog/clouds. As the air heats up these droplets evaporate back into vapur and are absorbed by the air - as vapour they are invisible.
The same amount off water (roughly) is present it's just that as widely spread individual water vapour molecules as a gas you can't see it, condensed into liquid water droplets in a fog it reflects and scatters light so you can.
Thanks for that explanation.
But how does that explain the fact that the fog starts just before (+-1 hour) the sun rises and not in the middle of the night?
Thanks.
Depending where you are, it can be the ground cooling down to draw wet air in from the ocean or mountains, or locallly it can be water from ground plants/dew.
You do get fog in the middle of the night - you just don't tend to notice it (unless driving!)
It's generally cooler at night than in the morning, so the liquid water settles to the ground as dew. With the sun up, evaporation starts. A lot of the water changes back and forth between the liquid and vapour states as it ascends, which is why you see mist rising from the ground in the morning.
Thanks.
It is coldest outside just before sunrise.
How does fog differ from a cloud?
Can a cloud exist above a substantial fog bank?
The only difference is in height above the ground. Both are composed of water droplets, water vapour, and sometimes ice crystals suspended in air. A lot of clouds are far more dynamic than fog simply because of the air currents at higher altitudes. Clouds will generally be colder as well, also due to altitude.
edit: I don't know where you guys live. What's really cool here is to see a couple of mountains in the Rockies engulfed in clouds, then visit one of the towns up there and find it foggy from their perspective.
1. What is fog?
Fog is a type of cloud that forms close to the ground, consisting of tiny water droplets or ice crystals that are suspended in the air.
2. How does fog form?
Fog forms when the air becomes saturated with water vapor, leading to the formation of tiny water droplets or ice crystals. This can happen when warm, moist air cools rapidly, causing the water vapor to condense into fog.
3. What are the different types of fog?
There are several types of fog, including radiation fog, advection fog, and upslope fog. Radiation fog forms at night when the ground cools, advection fog occurs when warm, moist air moves over a cool surface, and upslope fog forms when air is forced up a slope, causing it to cool and condense into fog.
4. How does fog disappear?
Fog can disappear in several ways. It can dissipate as the sun warms the air and surface, causing the water droplets to evaporate. It can also dissipate as the air temperature rises, causing the fog to mix with warmer, drier air. Wind can also blow the fog away, dispersing the water droplets.
5. Is fog dangerous?
Fog can be dangerous, particularly when driving, as it reduces visibility and can make it difficult to see and navigate. It can also cause flight delays and disruptions to transportation. Fog can also be hazardous to health, as breathing in high concentrations of water droplets can cause respiratory issues. It is important to take caution when fog is present and follow safety protocols.
  • Astronomy and Astrophysics
  • Electrical Engineering
  • General Discussion
  • Other Physics Topics
