Writing vectors in bold and with arrows in LaTeX?
3 replies · 332K views · last reply
IlyaZ
a. How do I write vectors bold within displaymath and frac. I want Phi, r and r_1 bold. But get G M_1 bold as well = bad.
b. How do I use arrows instead of the bold notation?
\begin{displaymath}
a1. textbf{\Phi(r)} = -\frac{G M_1}{| textbf{r}-textbf{r_1} |}
\end{displaymath}
a2. \bf{\Phi}(\bf{r}) = -\frac{G M_1}{| \bf{r}-\bf{r_1} |}
Arrows: \vec : [tex]\vec \Phi ( \vec r) = -\frac{G M_1}{| \vec{r}-\vec r_1 |}[/tex]
Bold: \mathbf : [tex]\mathbf{\Phi}( \mathbf{r}) = -\frac{G M_1}{| \mathbf{r}-\mathbf{r_1} |}[/tex]
I don't think you really want the potential to be a vector, but that's what your code implied, so I kept it.
You get other bad stuff as well using \textbf. Don't use it in math mode.
\textbf{\Phi(r)} = -\frac{G M_1}{| \textbf{r}-\textbf{r_1} |}
[tex]\textbf{\Phi(r)} = -\frac{G M_1}{| \textbf{r}-\textbf{r_1} |}[/tex]
\bf doesn't work at all:
[tex]\bf{\Phi}(\bf{r}) = -\frac{G M_1}{| \bf{r}-\bf{r_1} |}[/tex]
Timo suggested \mathbf, but that doesn't work on some things.
If you have access to the AMSLaTeX macros, (and you should), use \boldsymbol.
\boldsymbol{\Phi}(\boldsymbol{r}) = -\frac{G M_1}{| \boldsymbol{r}-\boldsymbol{r}_1 |}
[tex]\boldsymbol{\Phi}(\boldsymbol{r}) = -\frac{G M_1}{| \boldsymbol{r}-\boldsymbol{r}_1 |}[/tex]
Use \vec.
An even better solution is to define your own vector macro that formats vectors the way you want them to appear. For example,
\newcommand{\vect}[1]{\boldsymbol{#1}}​
Then when someone tells you to format your vectors with arrows instead you can simply change that one macro.
\newcommand{\vect}[1]{\vec{#1}}​
Bold symbols are used for things other than vectors (matrices, for example). A global search-and-replace is not a good idea.
