What Happens to Image Formation with Different Angles Between Plane Mirrors?
The angle between two intersecting plane mirrors directly affects the number of images formed, calculated using the formula (360/angle) - 1. For a 60-degree angle, this results in five images. The discussion raises questions about the outcomes for angles of 65 and 42.6 degrees, prompting further exploration of the formula's application. Visualizing the light rays through drawing aids in understanding the concept.
physicolic
As we know if the angle between two intersecting plane mirrors is 60 degrees 360/60 minus 1= 5 images of an object between the mirrors are formed. what will happen if the angle is 65 or 42,6 degrees?
Do you know WHY you get that result for 60 degrees?
(Draw a picture.)
thank you i just understood.
I draw the rays of light and saw the answer. thanx
