What was the bullet's speed as it left the barrel?
  • Thread starter AvrGang
  • Tags
    Speed
In summary, the student is a freshman struggling with a projectile motion assignment that is due on September 30th. They are stuck on three particular problems involving time, speed, and distance in a projectile's motion. With the help of other students, they were able to solve the first two problems and are now working on the third problem, which involves a car driving off a cliff at an angle. They have received hints and guidance from other students and are still working on the problem.
AvrGang
28
I'm a freshman student in the university, and I have to solve 50 questions to finish my assignment on the projectile motion, and I'm stuck with these three questions. I wish anybody can help me as fast as he or she can, because it's my first time to study the projectile motion. (My assignment is due to sunday 30th september).
Here is the first problem: A refile is aimed horizontally at a target 50 m away. The bullet hits the target 2.0 cm below the aim point.
a. What was the bullet's flight time?
b. What was the bullet's speed as it left the barrel?
My second problem: A projectile is fired with an initial speed of 30 m/s at an angle of 60(degrees) above the horizontal. The object hits the ground 7.5 s later.
a. How much higher or lower is the launch point relative to the point where the projectile hits the ground?
b. To what maximum height above the launch point does the projectile rise?
c. What are the magnitude and direction of the projectile's velocity at the instant it hits the ground?
The final problem is: A stunt man drives a car at a speed of 20 m/s off a 30-m-high cliff.
The road leading to the cliff is inclined upward at an angle of 20(degrees).
a. How far from the base of the cliff does the car land?
b. What is the car's impact speed?(I didn't understand what is an impact speed)
The range equation: d=((Vi)2.sin(2@))/g
Xf= Xi + Vixt
yf= yi + Viyt - 1/2g(t)2
g= 9.8 m/s2
I didn't understand these three problems, even i didn't know how to draw them, so please help me because I'm tired from the other problems that i had solve.
I'm logged on for any discussion
First Question: What was the initial vertical component of the bullet's velocity, what was the vertical distance traveled, and what was the vertical accelleration? Do you have an equation which relates these three things to find time?
Second Question: Again, you know the all the information about the vertical components of the motion, except the final position, can you solve for this?
Third Question: Impact speed is the speed it has just before hitting bottom. This question follows similar ideas to the last two.
There are two things to consider here: the bullets' horizontal velocity and its vertical velocity. There is no acceleration on the bullet after it has left the rifle's barrel. Therefore, the only acceleration is in the downward direction due to the force of gravity given by g=9.8m/s^2.
Write out the equations of motion for the x and y axes respectively and solve them for the time taken.
Aha... Thanks for helping me , i'll try now
Hi,
The first question is easier than the other two.For the first one you will have to consider that the distance covered in the y direction is 2cm.And the distance traveled in the x direction is 50 m.Now i think that you must do the question by applying the normal laws of kinematics and projectile motion.
For the second question. Find out the time taken by the projectile to travel the whole distance. If the time is greater than 7.5 seconds than it means that after 7.5 seconds the projectile is still in motion and it is above the launch point by a certain amount of height.That you can solve by the equation
[tex]d_y = v_0\sin\theta{t} + \frac{at^2}{2}[/tex]
Now for the third question there is an equation for it. Do you know that equation it is different than the three conventional equations which we have.
I wish i know it
but thank you for helping me
AvrGang said:
I wish i know it
Dont worry.
So did you get the first two. If yes than we may discuss the equation for the third question
ok i solved the first one
I'm now solving the second one
ok can we return to the second question
Here is my answer:
d_y = 30sin60(7.5)-0.5(9.8)(7.5)^2
d_y = -80.8m
How i can know if it's higher or lower?
I solved question a) in the second question
please someone help me in b)To what maximum height above the launch point does the projectile rise? In the second problem
Here is my answer:
d_y = -80.8m
I think that there is something wrong.Hold on.
Thank god I finally solved the first two questions, thank you guys for helping me
Ill work now on the third question which is:
I think this question is harder that the first two
I'll work now on it
but please if you have any hint please tell me
I'll still outline
the second question is higher because of the (-) sign which means in the opposite direction of our convention( i choose the up direction to be positive)
Here is my answer:
d_y = -80.8m
It is lower. Because if you count the time where the whole land is of same level than you will find that t=5.29 seconds.Hence the ball might have touched the ground after 5.29 seconds if the land was levelled . But it has taken some more time and hence it is lower than the shooting point.
So have you got the correct answers of part 1 and part 2.
The part three is not what i thought. It does not need any complicated equation. But now looking at the problem i feel that either the question is incomplte or i think that i have misunderstood the question.
Is the take of velocity of the car 20m/s? Or is it the velocity when the car is during the flight and that also when it is exactly above the highest point of cliff?
I finished my assignment
Thank you all
1. What is the average speed of a bullet as it leaves the barrel?
The average speed of a bullet as it leaves the barrel can vary depending on several factors such as the type of gun, the type of bullet, and the amount of gunpowder used. However, on average, a bullet can leave the barrel at speeds of around 1,700 miles per hour.
2. How does the length of the barrel affect the bullet's speed?
The length of the barrel can have a significant impact on the bullet's speed. A longer barrel allows for a longer acceleration time, resulting in higher speeds. However, there is a point of diminishing returns, and a barrel that is too long can actually decrease the bullet's speed.
3. Can the bullet's speed be affected by temperature?
Yes, temperature can affect the bullet's speed. In colder temperatures, the gunpowder may burn slower, resulting in a decrease in bullet speed. In hotter temperatures, the gunpowder may burn faster, resulting in an increase in bullet speed. However, the effect of temperature is relatively small and may only result in a difference of a few feet per second.
4. How do different types of bullets impact the speed at which they leave the barrel?
The type of bullet can greatly impact the speed at which it leaves the barrel. For example, a lighter bullet will generally have a higher velocity than a heavier bullet. Additionally, the shape and design of the bullet can also affect its speed. Bullets with a more aerodynamic design will typically have a higher velocity.
5. Is there a way to measure the exact speed of a bullet as it leaves the barrel?
Yes, there are various methods for measuring the speed of a bullet as it leaves the barrel. One common method is using a chronograph, which measures the time it takes for the bullet to pass through two sensors placed a known distance apart. This time can then be used to calculate the bullet's speed. Another method is using high-speed cameras that can capture the bullet in motion and calculate its speed based on the distance traveled in a known amount of time.
