Help Uncertainity principle problem
To determine the limit of accuracy for locating a particle along the x-axis using the uncertainty principle, the relationship delta(x) * delta(Px) ≥ h/4π is essential. Given the mass of 2x10^-4 kg and the velocity measurement accuracy of ±10^-6 m/s, one can calculate delta(Px) by multiplying the mass by delta(Vx). The discussion also touches on the concept of black holes and density, questioning the apparent contradiction of measuring mass and volume in relation to density. Overall, the thread emphasizes the importance of showing work for clarity and assistance in quantum mechanics problems.
indiepunkband
in my problem i am told
that the x-component of the velocity of a 2x10^-4 kg mass is measured to an accuracy of +_ 10^-6 m/s.
i need to find the limit of the accuracy with which the particle can be located along the x-axis.
the uncertainity principle
delta(x) * delta(Px)>= h/4pi
i have delta(Vx) and i need delta(x)
help please
this is not homework sub-forum, here we post general questions about QM.
someone will move this thread to the right sub-forum, just so know in the future.
Also you need to show some work before you get help.
but I can give you a hint: calculate the deltaP, you have mass and deltaV, it is straightforward.
If black holes are described as having no volume of space, yet they are 'mass" via density.
Mass density= MASS per VOLUME of SPACE.
So, density = mass per volume, & in order to MEASURE the density of something is to measure its MASS, then measure its VOLUME then divide MASS/VOLUME.
Why does there seem to be a contradiction?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
