Finding the Minimum Current for Magnetic Force to Equal Wire Weight
  • Thread starter Thread starter Turbo Math
    Magnetic
The discussion focuses on calculating the minimum current required for the magnetic force on a wire to equal its weight. The wire has a mass of 0.18 grams per meter and carries a current of 1 A in a magnetic field of 0.5 T directed horizontally upwards. The relevant equation used is F = BIl sin θ, leading to the conclusion that the minimum current needed is 0.0036 A when the angle θ is 90 degrees, indicating that the magnetic field is perpendicular to the wire.
  • Understanding of magnetic force equations, specifically F = BIl sin θ
  • Knowledge of basic physics concepts such as weight and mass
  • Familiarity with units of measurement in physics (grams, amperes, teslas)
  • Ability to perform trigonometric calculations, particularly using sine functions
  • Study the principles of electromagnetism, focusing on the Lorentz force
  • Learn about the applications of magnetic fields in engineering
  • Explore the relationship between current, magnetic fields, and forces in different configurations
  • Investigate the effects of varying angles in magnetic force calculations
Students in physics, electrical engineering majors, and anyone interested in understanding the principles of magnetic forces and their applications in real-world scenarios.
Turbo Math
A wire extends horizontally from east to west. The mass of its meter is (0.18)g and it carries a current of (1)A. If the wire is in a magnetic filed (0.5)T that heads horizontally upwards, determine the least current that makes the magnetic force equal the wire weight
F = BIl sin θ
at first i don't understand what does "heads horizontally upwards" means so this is where i end up:
mg = BIl sin θ
(0.18E-3) x 10 = 0.5x1x1 sin θ
θ = sin^-1(1.8E-3/0.5)
θ = 0.2
I think horizontally upwards means perpendicular to the wire(direction of the current)
You mean..
BIl = mg
0.5 I = 1.8E-3
I = 0.0036 A ?
  • · Replies 35 ·
