How to Calculate Magnetic Field in a Toroid Using Ampere's Law?
The problem involves calculating the magnetic field inside a toroid using Ampere's law, with specific parameters including the number of turns and the inner and outer radii of the toroidal coils.
  • Exploratory, Assumption checking
  • Participants discuss the relevance of the inner and outer radii in the context of applying Ampere's law, with some questioning whether these dimensions affect the calculation of the magnetic field.
Some participants have provided clarifications regarding the use of the radii in the calculation, while others are exploring the implications of these dimensions on the magnetic field. There is an ongoing exploration of the relationship between the defined parameters and the application of Ampere's law.
Participants are navigating the specifics of the problem setup, including the interpretation of the inner and outer radii and their significance in determining the magnetic field within the toroid.
sfdevil
Use Ampere’s law to calculate the magnetic field inside of a toroid with 850 turns. The inner radius of the rectangular coils is 3.00 cm, the outer radius is 7.00 cm.
ampere's law: path integral(B*ds) over a closed path is equal to the enclosed current times mu_0
by ampere's law for toroids, I get B= mu_0*N*I/(2*pi*R)
Im confused as to what the inner and outer radius have to do with this problem,
hence the cry for help :(
anyone ?
The two radii are there so you can determine the axis of toroidal coils. This is chosen as it simplifies Amperes circuital law to the equation you have stated.
so basically these numbers don't really matter, right ?
since I am finding the magnetic field inside the toroid, its just going to be r as an arbitrary length from the center to some point inside (between 3 and 7 cms) ...correct ?
if so, then the final solution is mu_0*850*I/(2*pi*R), right ?
so from that explanation, I got that since inner radius is 3 and outer is 7, then radius of the rectangular cross-section is 4/2=2
so r=3+2=5
thats about as much as I could get from that page, please let me know If I am still missing something...
That should be ok.
