| Thread Closed |
momentum final velocity |
Share Thread |
| Jan3-08, 06:48 PM | #1 |
A constant force of 4.0 N to the right acts on a 3.0 kg mass for 0.45 s. a)Find the final velocity of the mass if it is initially at rest. b)Find the final velocity of the mass if it is initially moving along the x-axis with a velocity of 12 m/s to the left. 2. Relevant equations F=p/t 3. The attempt at a solution okay so for the a i got 0.6 using vf=Ft/m and just plugged in. but for b i don't know what to do..need your help thanks! |
| Jan3-08, 06:51 PM | #2 |
Recognitions:
First part is correct.
Use the formula [itex]F=\frac{mv-mu}{t}[/itex] where m is mass,v is final velocity and u is the initial velocity and t is time.(Newton's 2nd law) Also remember that velocity is a vector quantity so you should give a direction when you are stating your answers. |
| Jan3-08, 07:02 PM | #3 |
ok i used the formula but i have a feeling i calculated it wrong..i got 28 m/s, to the left
| Jan3-08, 07:14 PM | #4 |
Recognitions:
[tex]v=\frac{Ft+mu}{m}[/tex]
[tex]v=\frac{(4*0.45)+3*-12}{3}[/tex] is that what you did? which would give you 11.4 ms[itex]^{-1}[/itex] to the left |
| Jan3-08, 07:16 PM | #5 |
so... -11.4 but my teacher said none of the answers are to be negative so would i still have the same answer but just without a negative sign?
| Jan3-08, 07:19 PM | #6 |
Recognitions:
Well a vector quantity has both magnitude and direction. So I just took the right as +ve and left as -ve. so the magnitude of the velocity is 11.4ms^-1
| Jan3-08, 07:26 PM | #7 |
Thanks! i guess my teacher would just assume left and right without the signs..that was a lot of help!:)
| Thread Closed |
Similar discussions for: momentum final velocity
| [SOLVED] Final Velocity (involving momentum) | Introductory Physics Homework | 1 | ||
| Ratios of Initial to Final Energy/Momentum/Velocity | Introductory Physics Homework | 1 | ||
| Final Velocity | Introductory Physics Homework | 7 | ||
| Final velocity | Advanced Physics Homework | 5 | ||
| final velocity of car | Introductory Physics Homework | 5 | ||
