Is Work Done by Gas or Gas and Spring Both?
  • Thread starter Thread starter i_island0
    Gas
In the scenario of a horizontal cylinder with a frictionless piston containing a mono-atomic gas, the application of the first law of thermodynamics requires careful consideration of work (W). When calculating W, it is essential to determine whether the focus is on the gas alone or the combined gas-spring system. If only the gas's internal energy change is considered, W should reflect the work done by the gas. Conversely, if the internal energy change of the entire gas-spring system is analyzed, W must include contributions from both the gas and the spring. This distinction is crucial for accurately applying the first law of thermodynamics.
i_island0
A horizontal cylinder is fit with a frictionless and massless piston. Inside the cylinder there is a mono-atomic gas. Outside pressure is Po. The piston is connected with a spring (of spring constant K) the other end of which is connected with the walls of the cylinder. (the spring lies withing the cylinder).
My question is when we use first law of thermodynamics, W + delta(Q) = delta(E_int).
then shall we calculate the 'W' as work done by the gas, or work done by the gas and spring both. Please explain the reason as well.
To do this problem, I am using the equation, that I learned in work energy theorem; W + delta(Q) = delta(K) + delta(U) + delta(E_int).
Here, i am using delta(K) = 0 as i am not considering velocity of COM of the system.
The first law of thermodynamics is simply a statement of the principle of conservation of energy. See http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/firlaw.html#c1" for more information. So if you are calculating the change in internal energy of the gas, then dW should be the work done by the gas, but if you are considering the change in internal energy of the gas-spring system then dW would be the work done by both the spring and the gas.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
