Math Physics Tricky Integrals go Over my Head
dazednconfuze
so i have this question about a ladder and the area under it and when it all comes down to it I get the integral, ∫ u2 ( 1 – u2 ) 3/2 du, from u = 0 to u = 1.
I am not sure whether to use trig substitution. I keep ending up in the same boat when I do. . . And the same thing when I do integration by parts. I'm not too quick with integration obviously. any help?
is u2 u*2?
I'm almost going to have to guess it's u*(1-u)^(-3/2) that's giving you trouble(or 2*u or whatever)
in which case I think integration by parts will do it
What's the actual problem though?
I assume you mean \int_0^1 u^2(1-u^2)^{3/2} du.
Let u=\sin\theta and brush up on your trig.
Use the formulae for sin and cos of theta/2.
oh ok, that makes more sense with what he typed >_>
You'll need those trig identities, but you can find huge tables of such identities in moments courtesy of the internet
I tried substituting u = sin(theta) and all I got was sin^2(theta) cos^4(theta) dtheta... and that just doesn't mean anything to me...
\int \sin^2 \theta {} \cos^4 \theta {} {} d\theta = \frac{1}{4}\int \sin^2 2\theta \ \frac{1+\cos 2\theta}{2} {} d\theta
Can you carry on from here ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
