| Thread Closed |
Potential that has had me stuck for hours |
Share Thread | Thread Tools |
| Feb24-08, 02:31 PM | #1 |
A total amount of positive charge Q is spread onto a nonconducting, flat, circular annulus of inner radius a and outer radius b. The charge is distributed so that the charge density (charge per unit area) is giver by o = k/r^3, where r is the distance from the centre of the annulus to any point on it. Show that (with V = 0 at infinity) the potential at the centre of the annulus is given by:
V = (Q/8pie)((a+b)/ab) so I have dV = (1/4pie)(dQ/r) dQ = odA = o2pirdr = 2piQdr/r^2 I'm really confused about the k in o = k/r^3 I'm thinking it must either be the constant k = 1/4pie, but my professor never rights that as k, so I'm thinking that k=Q because otherwise I don't see a way to have Q in the expression. So I tried taking the integral of that expression from a to b with plugging dA and o in, but I'm not getting what I need. Any help is much appreciated! Thanks |
| Feb24-08, 02:37 PM | #2 |
To find k: You are given the total charge (Q) and the charge density. Integrate the charge density over the annulus to get an expression for the total charge. Equate this with Q and solve for k.
| Feb24-08, 02:46 PM | #3 |
so if i integrate the charge density from a to b i get -2k/r^2
Q = -2k/r^2 k = -qr^2/2 is this correct? how will i get rid of this negative? |
| Feb24-08, 03:16 PM | #4 |
or do i do:
odA = dQ Q = -4pik((1/b)-(1/a)) Q = 4pik((b-a)/ab) k = Qab/4pi(b-a) |
| Feb24-08, 03:34 PM | #5 |
Your second post is good, except you should check your work. Bringing the negative into the parentheses should change b-a to a-b, and from where did you get the 4?
| Feb24-08, 03:45 PM | #6 |
i used the - to make it 1/a - 1/b
then changed it to b-a/ab so i was back at b-a the 4 i got from dA = 2pirdr then *-2 from the integral i used o=k/r^3 and odA = Q should i just use o=k/r^3 to get Q = -2k(1/b - 1/a) k = (Q/2)(ab/b-a) once i get k, what do i do with it? |
| Feb24-08, 03:48 PM | #7 |
thats not right, without the dA i end up with
Q = -2k(1/b^2 - 1/a^2) |
| Feb24-08, 03:56 PM | #8 |
Sorry, that was my mistake. Your b-a is correct, but your k still isn't completely right. You are missing a [itex]\pi[/itex] in there.
After you find k, you should then integrate to find the total potential. Remember, that [tex]V = \int \frac{k \cdot dq}{r}[/tex] EDIT: How are you finding Q? It should be the case that [tex]Q = \int dq = \int_a^b 2\pi r \sigma \cdot dr[/tex] |
| Feb24-08, 04:00 PM | #9 |
i figure i must be integrating dQ = odA from a to b
dq = int k/r^3 dA but i know dA = 2pirdr is that correct? i dont know how to integrate that |
| Feb24-08, 04:02 PM | #10 |
Yes, that is correct, What you basically have is
[tex]dq = \sigma dA = \frac{2\pi k \cdot dr}{r^2}[/tex] then [tex]Q = \int_a^b \frac{2\pi k \cdot dr}{r^2}[/tex] which you can do, because it is just using the power rule (take out the constants first). You almost had it right the first time. |
| Feb24-08, 04:03 PM | #11 |
or will it be Q = 2pik * int dr/r^2
| Feb24-08, 04:04 PM | #12 |
that was what i did back when i got: k = Qab/4pi(b-a)
| Feb24-08, 04:07 PM | #13 |
Yes, you are right, but try integrating
[tex]\int \frac{dr}{r^2}[/tex] again. If you do it correctly, then solve for k, you should have a 2, not a 4. |
| Feb24-08, 04:10 PM | #14 |
ah yes, terrible mistake... brought over a -2 instead of a -1
so when i intergrate the final part dV = kdQ/r do i want to have dQ = odA integrating that will give me what i got for Q again and what do i do with the r? |
| Feb24-08, 04:26 PM | #15 |
Not quite, because you this time you are integrating dQ/(4[itex]\pi\epsilon r[/itex]), not just dQ, as you did when finding what k equals in terms of Q. Furthermore, you can replace the k in [itex]\sigma[/itex] with whatever you found k to be in terms of Q, a, and b.
| Feb24-08, 04:35 PM | #16 |
i can take out the 4pie as a constant so im left with integrating dQ/r which im not sure how to integrate..
do I want to change dQ to odA then everything is in terms of r dV = odA/r4pie = k2pirdr/(r^4)(4pie) V = int dV = (Q/4pie)(ab/b-a) * int dr/r^3 = (Q/4pie)(ab/b-a)(-2)(1/b^2 -1/a^2) is this correct so far? |
| Feb24-08, 04:38 PM | #17 |
this leaves me with the correct answer, except with 2pie on the bottom instead of 8pie (I had a factor of 2 in the numerator instead of denominator)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Potential that has had me stuck for hours
| electric potential no clue and midterm in 2 and a half hours | Introductory Physics Homework | 3 | ||
| 24 hours in a day? | General Discussion | 13 | ||
| work function for a certain metal is 1.5 eV, what is its stopping potential ? stuck! | Introductory Physics Homework | 5 | ||
| Rotation qns which i am stuck for 2 hours | Introductory Physics Homework | 3 | ||
| Help Been Stuck on these for hours! | Introductory Physics Homework | 3 | ||
