Angular Acceleration of at woods machine
The discussion revolves around calculating the acceleration of two masses in an Atwood's machine, taking into account the moment of inertia of the pulley. The user initially struggles with understanding torque and the normal force but later finds an online solution. They seek clarification on how to determine the tension on each side of the pulley, indicating that the tensions are not equal due to the pulley’s moment of inertia. The conversation highlights the complexities of analyzing systems with rotational dynamics. Understanding the differences in acceleration when the pulley’s moment of inertia is considered versus when it is ignored is crucial for solving the problem.
meganw
An Atwood's machine consists of two masses, m1 and m2, which are connected by a massless inelastic cord that passes over a pulley, Fig. 10-70. If the pulley has radius R and moment of inertia I about its axle, determine the acceleration of the masses m1 and m2 (a), and compare to the situation in which the moment of inertia of the pulley is ignored (a0). [Hint: The tensions FT1 and FT2 are not necessarily equal.] (Use m_1 for m1, m_2 for m2, R_0 for R0, and g and I as appropriate.)
a= _________
a(0)= _________
T = I * a(angular) = F*d*sin90
Attempt at Solution: I was trying to sum the forces and use Torque but I have NO idea what Torque is or what the value of the normal force is. :(
Before you mark this as solved, does anyone know how to find the tension on each side of the pulley?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
