Solving the Mystery of Quadratic Equations
The term "quadratic" derives from the Latin word "quadratus," meaning "square," which refers to the squared variable in the leading term of a quadratic equation. This connection explains why quadratic equations are associated with the concept of squaring rather than the number four. The discussion highlights the semantic confusion surrounding the term, as "quad" typically denotes four. Additionally, a rectangle with equal sides, resulting in an area represented by x^2, is indeed called a square, reinforcing the link between the term and its mathematical meaning. Understanding this etymology clarifies the terminology used in mathematics.
Wannabeagenius
Hi All,
I have a semantics question.
Why is the quadratic equation called what it is?
A polynomial of degree two is called a quadratic polymonial but I've always associated the root quad to mean four!
Thanks in advance.
Bob:smile:
Mathematics news on Phys.org
From wikipedia, "Quadratic equations are called quadratic because quadratus is Latin for "square"; in the leading term the variable is squared."
I always wondered that as well to be honest.
Well, what do you call a rectangle whose length is x and breadth is x, and whose area is x^2?
Not a..square?
If you get exercised over this sort of thing (I know I do!), you might find this website to be of interest:
http://pballew.net/etyindex.html
It notes that "quadratic" is from the Latin for "to make square" or, as Lamoid said, simple "square". Of course, a square has four sides which is where your use of the word is from.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
