Proving Set Subset Relationships to (X/B) and (X/A) Union"
  • Thread starter Thread starter chocolatelover
    Operations Sets
The problem involves proving a set relationship, specifically that set A is a subset of set B if and only if the complement of B in X is a union of the complement of A in X. The discussion revolves around understanding set operations and the implications of subset relationships.
  • Participants explore the meaning of the terms "union" and "complement" in the context of set theory. There is an attempt to clarify the contrapositive of the original statement and its implications. Questions arise regarding the definitions and operations involved in the problem.
The discussion is ongoing, with participants seeking clarification on terminology and the logical structure of the proof. Some guidance has been offered regarding the nature of subset proofs and the correct interpretation of set operations, but no consensus has been reached on the approach to take.
There appears to be confusion regarding the notation used for set operations, particularly the distinction between union and set difference. Participants are also questioning the definitions and implications of the terms used in the problem statement.
chocolatelover
Prove the following statement:
A is a subset of B if and only if (X/B) is a union of (X/A)
I really don't understand how to prove these types of problems. I was thinking about proving the contrapositive, which would be If A is not a subset of B, then (X/B) is not a union of (X/A), right?
Could someone please show me what to do?
Thank you very much
I don't quite understand what you mean when you say X/B is not a union of X/A. Can you clarify please?
What do "(X/B) is a union of (X/A)" and "(X/B) is not a union of (X/A)" mean? I only know "union" as an operation on two sets.
Oh, and the contrapositive of "if A then B" is NOT "if not A then not B". That is the inverse and the truth of one does not imply the truth of the other. The contrapositive is "If not B then not A" and, here, that would be "If (X/B) is not a union of (X/A) then A is not a subset of B" though I still don't know what "union" means here!
Is it possible that you just meant to have "subset" again? "If X is a subset of B then (X\B) is a subset of (X\A)" is a true statement. (Notice also that I have reversed "/" to "\". "/" implies a division (which is not defined for sets) while "\" is the "set difference".
If that is true, that you want to prove "If X is a subset of B then (X\B) is a subset of (X\A)", I would not try to prove the contrapositive but prove it directly. The standard way to prove "P is a subset of Q" is to say "if x is a member of P" and prove, using whatever properties P and Q have, "therefore x is a member of q".
Here, you would start "if x is a member of (X\B), then x is a member of X but x is NOT a member of B" (using, of course, the definition of "X\B"). Now, what does that, together with the fact that A is a subset of B, tell you about whether or not x is a member of A?
Thank you very much
By "union" I ment that "X is such that x is an element of A or x is an element of B" Could you please show me what to do in this case?
Thank you
