| Thread Closed |
Acid + Alcohol |
Share Thread |
| Mar10-08, 12:42 PM | #1 |
Acid + Alcohol
hi
i have the following reaction isobutyric acid + 2-methoxyethanol <-> 2-methoxyethyl-2-methylpropanoate but i don't know all of the by-products. please help thanks edit: i think is only water and some unreacted reactants? |
| Mar10-08, 02:20 PM | #2 |
Recognitions:
Acid is RCOOH and the alcohol is R'OH. Yes water will be a by-product. But how do you get water from this? (The -OH from the acid and the H from the alcohol bond together to form the water) What you are left with will form the other product.
(btw were there any conditions for this reaction?) |
| Mar10-08, 02:41 PM | #3 |
no, because i am suppose to make procedure to create the product
so i will have to change the condition to shift equilibrium to the right side i guess... why? |
| Mar11-08, 05:45 PM | #4 |
Recognitions:
Acid + Alcohol
Because an acid and alcohol react to give ester and water in the presence of H+ as a catalyst.
| Mar11-08, 07:24 PM | #5 |
thanks for confirm, rock
| Mar12-08, 08:48 AM | #6 |
Just to name what your doing (basically acid catyzed dehydration of an alcohol is what your doing).
| Thread Closed |
Similar discussions for: Acid + Alcohol
| Making Wood Alcohol/Methyl Alcohol | Chemistry | 9 | ||
| Organic Chemistry: acid pKa of a substituted phthalic acid | Biology, Chemistry & Other Homework | 12 | ||
| acidity of fumaric acid and maleic acid | Chemistry | 4 | ||
| calculating molecular mass of oxalic acid (diprotic acid) using only given #s? | Biology, Chemistry & Other Homework | 1 | ||
| titrating weak acid buffer with strong acid after the base is used up | Biology, Chemistry & Other Homework | 6 | ||
