Thread Closed
Needed: Equation for line drag in water
Share Thread Thread Tools
Apr16-08, 03:34 PM   #1
First off, a thousand apologies if this is in the wrong forum!
I have seen the other posts regarding calculating line drag in water for things being towed in water, however, I have the somewhat opposite requirement.. Here is what I know:
  • hydrodynamic object being towed along surface by underwater vehicle
  • depth of underwater vehicle: 30'
  • water type: salt water
  • line diameter: <0.25"
  • line length: 45'
  • speed of underwater vehicle: 5kts or 2.6m/s
What I am hoping is that someone could provide an equation that would give me the maximum drag. My thinking is that if I have the maximum drag then I will know the minimum line strength required as well as minimum buoyancy required for the towed object on the surface, right? I'm also hoping that I can change the line diameter and line length variables to change the final drag value.
As you can tell, these types of calculations are not my area of expertise, and any additional input/guidance is greatly appreciated!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Thread Closed
Thread Tools
Similar Threads for: Needed: Equation for line drag in water
Thread Forum Replies
equation of line parallel to plane and intersaction with other line Precalculus Mathematics Homework 5
Water Rocket-density,temp,drag General Physics 0
Calculating viscous drag in water Mechanical Engineering 2
Drag coefficient PVC over water Mechanical Engineering 9
coefficient of drag of an object in water General Physics 4
