Thread Closed
Horn Antenna Radio Interferometer
Share Thread
Apr21-08, 03:55 PM   #1
This is a strange experiment (or not so compared to some of the experiments I've done) that I am currently undertaking, and require your help.
I have built an interferometer of sorts. Two metal funnels of diameter 200mm are attached together by copper tubing (20mm?) through a Y junction with all angles of 120 degrees. The distance between the centre of the funnels is 600mm. The lower tube connects directly into an LNB.
I am trying to connect the LNB to a voltage data logger via a device called a satellite finder that is basically an analogue dial voltmeter. Currently the software isn't working, but it should do the job.
What I need your help with.
I don't know if it (what ever it is) will work, and if it does, why? I can't find any (seemingly) relevant equations.
PhysOrg.com physics news on PhysOrg.com
>> Cheap, color, holographic video: Better holographic video displays
>> First entanglement between light and optical atomic coherence
>> EUROnu project recommends building Neutrino Factory
Apr21-08, 04:24 PM   #2
Recognitions:
Homework Helper Homework Help
Unless there is some sort of mixer in the Y junction you haven't built an interferometer.
It sounds like you are trying to make a directional signal detector.
I would have thought you want to connect a LNB to each funnel and measure the relative signal strength of each.
You will have to do some caibration because the Feed+LNBs are unlikely to be perfectly equal gains and sensitivity.
May5-08, 04:14 AM   #3
Got this setup and it actually works! One can see some excellent fringes when a person walks past it, and there's certainly some stuff going on when a sweep of the sky is made.
can anyone give me an equation relating the intensity of the em radiation detected and the size/angle of the horns? Or just some general electrostatics relations
May13-08, 04:43 PM   #4
If anyone is interested, it works exceptionally well. Interference fringes are observed, and when sweeping the southern horizon, a pattern that is significantly similar to that obtained with a standard parabolic reflective dish is observed.
Thread Closed
Similar discussions for: Horn Antenna Radio Interferometer
Thread Forum Replies
Satellite TV & Radio dish & antenna question Electrical Engineering 19
Frequency of horn Introductory Physics Homework 4
How does a Radio Antenna Work? General Physics 8
Inductance caused by radio antenna Introductory Physics Homework 0
