What is the frequency of a gamma particle with an energy of 4.5 MeV?
  • Thread starter Thread starter WPCareyDevil
    Frequency
A gamma particle with an energy of 4.5 MeV can be analyzed using the formula E=hv, where E is energy, h is Planck's constant, and v is frequency. The participant initially attempted to use the formula d=vt, which is incorrect for calculating frequency. After clarification, they recognized that gamma particles are a form of electromagnetic radiation, specifically photons. By applying the correct formula, they were able to connect the energy of the gamma particle to its frequency. Understanding the relationship between energy and frequency is crucial in solving such problems.
WPCareyDevil
[SOLVED] (101)Gamma frequency?
A gamma particle of energy 4.5 MeV is detected as a product of some nuclear reaction (4.5 MeV is 0.72 pJ). What is the frequency of this gamma radiation?
I tried using d=vt because it was the closest formula I could find in my notes that had anything to do with frequency. I assumed v=3x10^8. Of course, the answer was not correct. Could someone point me in the right direction here? I figured out every other problem but this one, and I only have 1 attempt left
Hi WPCareyDevil,
What is a gamma particle? (For example, an alpha particle is a helium nuclei, a beta particle is an electron or positron.) Once you identify what it is, what is the formula for its energy?
(I'm wondering about your choice of d=vt. Is it because of the v? If so, in this equation v is velocity, not frequency.)
Well I have done some research and Gamma particles are elctromagnetic radiation (light emission).. E=mc^2 obviously comes to mind, and I could find the mass of the particle, but how does frequency factor in?
I used d=vt because of the t (t^-1=frequency). It was a long shot and didnt make sense to me, but it was the closest I could find and every once in a while Ill connect with a shot in the dark on Webassign.
That's right; gamma particles are electromagnetic radiation, and when we speak of their particlelike nature we speak of photons.
So here you need the expression for the energy of a photon. What do you get?
Ah hah! I googled around and found Planck's constant as well as the formula e=hv where v is the frequency. That was something I didnt learn in class at all. Thanks for the help Alphysicist!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
