Solving Complex Gaussian Integral Problems
Pacopag
We know that
\int_{-\infty}^\infty e^{-ax^2}dx = \sqrt{\pi \over a}.
Does this hold even if a is complex?
In the derivation of the above equation, I don't see any reason why we must assume that a be real. So I think it does hold for complex a.
benorin said:
It holds for Re(a)>0.
Yes … it relies on e^{-ax^2}\arrowvert_{\infty}\,=\,0 .
If a = b + ic, then e^{-ax^2}=\,e^{-bx^2}e^{-icx^2} , which is 0 if b > 0, and really wobbly if b ≤ 0. :smile:
Great. Thank you for your replies.
Hi again. I'd just like to make a remark that is bothering me. I created this thread because I was trying to find a Green function and arrived at
G(x,x',t) = {1\over{2\pi}}e^{im(x-x')\over{2t}}\int_{-\infty}^\infty e^{-{it\over{2m}}\left(p-{m(x-x')\over t}\right)^2}.
Please ignore everything except the integral.
When I naiively use the gaussian integral formula in my original post, I get the correct answer. But according to what you said, I should not be able to do this since (i.e. Re(a)<0) in this case. Can you see any reason for this?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
