Dark Matter Halo + Virial theorem Q.
The discussion revolves around the application of the virial theorem to understand the velocity dependence on radius in dark matter halos, specifically for galactic rotation curves. The initial calculation of the potential leads to a logarithmic divergence, prompting a redefinition of the zero point for potential energy. This results in a velocity equation that incorrectly includes an arbitrary constant, which raises concerns about its physical relevance. The main issue identified is the distinction between galactic rotation curves and the random motion of galaxies, emphasizing that orbital velocity should relate to the enclosed mass rather than the potential itself. The conversation highlights the need for clarity in the assumptions made when applying theoretical frameworks to observational data.
neutralseer
A year ago we had a HW problem about galactic rotation curves:
If the dark matter density is
\rho= \frac{\rho_0}{1+\left(\frac{r}{r_0}\right)^2},
Then how does velocity depend radius at large r (r>>r_o)?
You want to use the virial theorem here, so you calculate M(r) and then finally calculate the potential:
\phi(r)=\int_{-\infty}^{r} \frac{k}{s}ds=\infty
with k = constant.
Oops, phi(r) diverges logarithmically. Oh well, you just have to set the zero point somewhere else besides infinity, say at a > r_0, so we get,
\phi(r)=k\ln{\frac{r}{a}}
Now, since the force between any two particles is an inverse square law, the virial theorem says:
2KE+PE=0. Thus we can write:
v=\sqrt{-\phi(r)} =\sqrt{ -k\ln{\frac{r}{a}}}.
Obviously, something is wrong with this answer. An observable quantity like the velocity, ‘v’, cannot depend on an arbitrarily chosen constant, ‘a’. Where did my logic go south?
Astronomy news on Phys.org
The problem is looking for the galactic rotation curve, not a bunch of galaxies moving randomly as is the case for observations such as that of the Coma cluster. The orbital velocity at radius ##r## is related to the enclosed mass ##M(r)##, which appears in the derivative of the potential, not in the potential itself.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
