Understanding Back EMF: Effects on Parallel and Series Electrical Circuits
  • Thread starter Thread starter moon2
    Back emf Emf
When an electric drill is turned on, it causes a surge of current that briefly dims the lights in parallel circuits. This flickering occurs due to the initial demand for power as the motor starts. Once the motor reaches operational speed, back EMF is generated, which opposes the current flow and reduces the overall current in the circuit. In series circuits, the lights would dim and remain dim due to the constant load. Understanding back EMF is crucial for analyzing how electrical devices affect circuit performance.
moon2
Ex:At home, you plug an electric drill into an electrical outlet and turn it on. At the moment you turn on the drill, the lights in the room(wired in parallel to the drill) flicker and dim briefly, but then return to normal after a moment.
notice that the example is wired in parallel, but in series lights will just get dim and stay the same.
what had happened in both of the case and how can i relate this to back emf?
When you turn the electric motor on, there is a surge of current, dimming other lights.
When the motor gets up to speed, there is a back EMF in the circuit which reduces the current through the motor.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
